“Two-Factor Authentication Reset”
Hello Umbrel community,
I accidentally deleted my Yubikey 2FA! My Umbrel session is still open, but I can’t disable the 2FA option in the settings without the required 6-digit code. I’m trying to disable this feature through the command terminal, but I don’t know the code to enter super-user mode. Could someone help me or give me precise instructions?
Kind regards.
Are you trying to enter through CLI? this might help
