Suddenly and after a restart my node mentions the 2FA is incorrect. I have tried several methods to solve this issue, re start, re-install umbrel on my raspberry but nothing helps.
Anyone has a different solution?
Also a question, how to restlet with seed phrase? Flashing the ssd in the raspberry pie does not give me this option.
Hi @castenigma,
This should help ![]()
hi!
i am facing the same issue.
after reflashing the umbrel os, MFA stopped working (not recognizing the authenticator code).
i use windows 10.
I tried to connect using PowerShell (ssh).
the command you gave above didn’t work. it says, “jq: error: Could not open file /home/umbrel/umbrel/db/user.json: No such file or directory.”
please help!!!
