After solving "There was an error connecting to LN Markets." and a few days I got this:
I did not change anything. Logs below:
lnmarkets
tor_server_1 | Sep 29 14:03:24.482 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_server_1 | Sep 29 14:03:24.000 [notice] Bootstrapped 0% (starting): Starting
tor_server_1 | Sep 29 14:03:24.000 [notice] Starting with guard context “default”
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor_server_1 | Sep 29 14:03:25.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor_server_1 | Sep 29 14:03:26.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor_server_1 | Sep 29 14:08:06.000 [warn] Unable to decompress HTTP body (tried deflated, on Directory connection (client reading) with 195.234.152.86:443).
tor_server_1 | Sep 29 14:08:09.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
tor_server_1 | Sep 29 14:08:09.000 [notice] Bootstrapped 40% (loading_keys): Loading authority key certs
tor_server_1 | Sep 29 14:08:10.000 [notice] Bootstrapped 45% (requesting_descriptors): Asking for relay descriptors
tor_server_1 | Sep 29 14:08:10.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6498, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
tor_server_1 | Sep 29 14:08:10.000 [warn] Tried connecting to router at 148.251.46.115:9001 ID= RSA_ID=758CA9651D8E9C508E6EDED59636560B8A9C7F1C, but RSA + ed25519 identity keys were not as expected: wanted 758CB9751D8E9C508E6EDED59636560B8A9C7F1C + no ed25519 key but got E4B0CAD11B5487C46293759A3D4B74484CF93509 + 7G+UIw9istNvDS1tLdZBhqcZuloINcOvbi63YdUWx7Q.
tor_server_1 | Sep 29 14:08:10.000 [notice] Bootstrapped 50% (loading_descriptors): Loading relay descriptors
tor_server_1 | Sep 29 14:08:13.000 [notice] The current consensus contains exit nodes. Tor can build exit and internal paths.
tor_server_1 | Sep 29 14:08:17.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_server_1 | Sep 29 14:08:19.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_server_1 | Sep 29 14:08:21.000 [notice] Bootstrapped 68% (loading_descriptors): Loading relay descriptors
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_server_1 | Sep 29 14:08:24.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_server_1 | Sep 29 14:08:27.000 [notice] Bootstrapped 100% (done): Done
tor_server_1 | Sep 29 16:25:22.000 [notice] No circuits are opened. Relaxed timeout for circuit 188 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway.
