After upgrade on LNMarkets I got this:
There was an error connecting to LN Markets. Error code: ECONNREFUSED
How to solve it?
How to solve it?
Hello @pantarhei!
My name is Max and I will be assisting you on this.
Let’s gather some more information so we can begin troubleshooting and come to a resolution:
Has this LNM system worked before?
Are any other integrations or applications not functioning correctly after the update?
What system/setup are you currently working on?
Please provide a log file whenever you have a moment.
Thank you,
Max
Thanks for the message. Yes, before the upgrade of Umbrel LNMarkets was working. I have found following log:
app_proxy_1 | [HPM] Error occurred while proxying request umbrel.local:4242/ to http://10.21.21.58:4242/
I use the newest Umbrel.
I also sent the issue here: [SOLVED] There was an error connecting to LN Markets. Error code: ECONNREFUSED · Issue #41 · ln-markets/umbrel · GitHub(no more info there)
Hi Pantarhei,
Please try the following for me: nano umbrel/bitcoin/settings.json file should be empty and modify it to contain.
If this does not work we will have the software development team get involved.
Thanks,
Max
Thank you Master Max. I did not have the directory bitcoin
, do not know the magic, but it works.
That’s wonderful to hear! If you need anything else let us know!
Thanks,
Max
