Since I updated Umbrel to the latest version there are problems with Lightning Terminal and the port.
“There was an error connecting to Lightning Terminal. Error code: EHOSTUNREACH”
Any ideas how to fix it?
Hi, restart node
I have been getting this a lot also. If I try to click on it maybe 10 times, in may connect once…so i rebooted, and still the same thing.
When i can log on to Lightning Terminal (1 in 10), and i enter my login details, all the red flags pop up on the right hand side (see image), but I can see my node details on the left hand side…and I do not know how to fix/stop it. I think I may have a issue with the file.
I deleted it and re-installed it…the same thing happens.
Any ideas?? Thanks.!
Screenshot 2023-05-02 at 2.21.03 PM|320x500
Did you get an answer to this? I am getting the same problem. Thank you
