The Bitcoin Machine, any way to lower LCD brightness?
The brightness on this thing is way too high. You can’t even read the screen unless you are right in front of it. At night just looks like a glaring white light. Any way to lower this?
I also would be very interested to solve this issue. If there is not solution to dim the screen, I will try it with ND film (neutral density film).
