Tailscale stuck on "starting..."
My tailscale is stuck on “Starting…”
when i look at my docker container, this is the message I get. Does anyone know what could be wrong?
2023-02-09 15:32:27 Feb 09 20:32:27.128 [notice] Tor 0.4.7.8 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
2023-02-09 15:32:27 Feb 09 20:32:27.128 [notice] Tor can’t help you if you use it wrong! Learn how to be safe at https://support.torproject.org/faq/staying-anonymous/
2023-02-09 15:32:27 Feb 09 20:32:27.128 [notice] Read configuration file “/tmp/torrc”.
2023-02-09 15:32:28 Feb 09 20:32:28.081 [warn] Unparseable address in hidden service port configuration.
2023-02-09 15:32:28 Feb 09 20:32:28.081 [warn] Failed to parse/validate config: Failed to configure rendezvous options. See logs for details.
2023-02-09 15:32:28 Feb 09 20:32:28.081 [err] Reading config failed–see warnings above.
Can you please try to uninstall and reinstall the Tailscale app, and let me know if that works?
Via Manage Apps > Click its red “X” > then navigate back to the app store and Install once more
Same here and already uninstalled and re-installed and even prune and ran script again and re-installed
no luck
I am having the same issue when using tailscale to access my node remotely over clearnet. Let me know if you figure it out. I am able to access my node with Zeus on my mobile using Tailscale.
Also trying to install tailscale on umbrell. After installing the app it gets stuck on “Starting…”
I tried this an still no luck
Anyone figure this out yet?
Since the tor service seemed to be the issue, I tried turning off Tor access and rebooting my Umbrel
However, I still have the same issue of not being able to access the app, this is the logs for tailscale_web_1: @usernameisJim
2023/05/05 21:31:37 web server running on: http://0.0.0.0:8240
2023/05/05 21:31:38 logtail started
2023/05/05 21:31:38 Program starting: v1.34.2-tc5ef9103d, Go 1.19.4-tse6ce5b5003: string{“tailscaled”, “–tun=userspace-networking”}
2023/05/05 21:31:38 LogID: 83f037310e604530e9f61bd65ba78e71475c2d794cedfa40861a7ffe821c4952
2023/05/05 21:31:38 logpolicy: using system state directory “/var/lib/tailscale”
logpolicy.ConfigFromFile /var/lib/tailscale/tailscaled.log.conf: open /var/lib/tailscale/tailscaled.log.conf: no such file or directory
logpolicy.Config.Validate for /var/lib/tailscale/tailscaled.log.conf: config is nil
2023/05/05 21:31:38 wgengine.NewUserspaceEngine(tun “userspace-networking”) …
2023/05/05 21:31:38 dns: using dns.noopManager
2023/05/05 21:31:38 link state: interfaces.State{defaultRoute=eno1 ifs={br-3fbee53b33e4:[172.18.0.1/16] br-8991ed235efe:[10.21.0.1/16] docker0:[172.17.0.1/16] eno1:[192.168.1.112/24]} v4=true v6=false}
2023/05/05 21:31:38 magicsock: failed to force-set UDP read buffer size to 7340032: operation not permitted
2023/05/05 21:31:38 magicsock: failed to force-set UDP write buffer size to 7340032: operation not permitted
2023/05/05 21:31:38 magicsock: disco key = d:29d6f09a7dda693a
2023/05/05 21:31:38 Creating WireGuard device…
2023/05/05 21:31:38 Bringing WireGuard device up…
2023/05/05 21:31:38 Bringing router up…
2023/05/05 21:31:38 Clearing router settings…
2023/05/05 21:31:38 Starting link monitor…
2023/05/05 21:31:38 Engine created.
2023/05/05 21:31:39 pm: migrating “_daemon” profile to new format
2023/05/05 21:31:39 got LocalBackend in 845ms
2023/05/05 21:31:39 Start
2023/05/05 21:31:39 Backend: logs: be:83f037310e604530e9f61bd65ba78e71475c2d794cedfa40861a7ffe821c4952 fe:
2023/05/05 21:31:39 Switching ipn state NoState → NeedsLogin (WantRunning=false, nm=false)
2023/05/05 21:31:39 blockEngineUpdates(true)
2023/05/05 21:31:39 health(“overall”): error: state=NeedsLogin, wantRunning=false
2023/05/05 21:31:39 wgengine: Reconfig: configuring userspace WireGuard config (with 0/0 peers)
2023/05/05 21:31:39 wgengine: Reconfig: configuring router
2023/05/05 21:31:39 wgengine: Reconfig: configuring DNS
2023/05/05 21:31:39 dns: Set: {DefaultResolvers: Routes:{} SearchDomains: Hosts:0}
2023/05/05 21:31:39 dns: Resolvercfg: {Routes:{} Hosts:0 LocalDomains:}
2023/05/05 21:31:39 dns: OScfg: {Nameservers: SearchDomains: MatchDomains: Hosts:}
2023/05/05 21:32:14 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58725, table=254
2023/05/05 21:32:14 monitor: RTM_DELROUTE: src=, dst=fe80::50d2:7cff:fef4:be3e/128, gw=, outif=58725, table=255
2023/05/05 21:32:14 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=58725, table=255
2023/05/05 21:32:25 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58737, table=254
2023/05/05 21:32:25 monitor: RTM_DELROUTE: src=, dst=fe80::8c80:d8ff:fe0d:a921/128, gw=, outif=58737, table=255
2023/05/05 21:32:25 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=58737, table=255
2023/05/05 21:32:32 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58739, table=254
2023/05/05 21:32:32 monitor: RTM_DELROUTE: src=, dst=fe80::d442:36ff:fe62:938/128, gw=, outif=58739, table=255
2023/05/05 21:32:32 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”)
2023/05/05 21:32:43 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”) (4 dropped)
2023/05/05 21:32:43 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58743, table=254
2023/05/05 21:32:43 monitor: RTM_DELROUTE: src=, dst=fe80::ac17:3fff:fe34:e698/128, gw=, outif=58743, table=255
2023/05/05 21:32:51 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”) (1 dropped)
2023/05/05 21:32:51 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58745, table=254
2023/05/05 21:32:51 monitor: RTM_DELROUTE: src=, dst=fe80::687c:a8ff:fe7b:4c63/128, gw=, outif=58745, table=255
2023/05/05 21:33:07 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”) (4 dropped)
2023/05/05 21:33:07 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58749, table=254
2023/05/05 21:33:07 monitor: RTM_DELROUTE: src=, dst=fe80::e48e:86ff:fe0f:1482/128, gw=, outif=58749, table=255
2023/05/05 21:33:07 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=58749, table=255
2023/05/05 21:33:23 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58751, table=254
2023/05/05 21:33:23 monitor: RTM_DELROUTE: src=, dst=fe80::10b6:6dff:fe8a:ee2c/128, gw=, outif=58751, table=255
2023/05/05 21:33:23 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=58751, table=255
2023/05/05 21:33:23 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”)
2023/05/05 21:33:52 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=58753, table=254
2023/05/05 21:33:52 monitor: RTM_DELROUTE: src=, dst=fe80::5024:bff:fe29:e3ae/128, gw=, outif=58753, table=255
2023/05/05 21:33:52 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=58753, table=255
UPDATE:
I solved it, here were my steps:
1.) Uninstall Tailscale
2.) In the Umbrel Settings, turn off Remote Tor access- let the Umbrel fully reboot
3.) Reinstall Tailscale
4.) On a device connected to the same network as the Umbrel, SSH into the device
5.) sudo ufw 8240
The app should then become accessible.
