raspi 4
Crucial MX500 1T SSD
Orico 2.5 in. enclosure model 2139C3
connected w/ Ethernet
I haven’t accessed Umbrel in a few months. but been up for maybe a year? Just noticed when accessing my Umbrel linked wallet on my phone, it wasn’t updating balance, so i tried to access Umbrel and got the " ERROR: System Service Failed" screen. I cannot log in
my debug log doesn’t look similar to others from what i can tell
I did directly unplug and plug back in RasPi before realizing that may be bad thing to do.
Initital Debug Log:
https://pastebin.com/WtHKjMwv
I then re flashed SD card to v0.4.14
Same error
I then plugged SSD into the other blue USB port
same error
I then tried a brand new SSD enclosure and USB cable
Same error
(all with proper shut downs in between)
Last thing would be to replace SSD
current Debug log:
https://pastebin.com/vB4TEquc
thank you
Maybe you have a full disc.
I think you may need a 2 GB ssd to run just half of the things offered by Umbrel system
Here is a failure i can see from my second (and most current) debug log:
Feb 14 10:27:00 umbrel umbrel startup[24586]: File "/usr/local/lib/python3.7/dist-packages/docker/api/client.py", line 222, in _retrieve_server_version
Feb 14 10:27:00 umbrel umbrel startup[24586]: 'Error while fetching server API version: {0}'.format(e)
Feb 14 10:27:00 umbrel umbrel startup[24586]: docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', ConnectionRefusedError(111, 'Connection refused'))
Feb 14 10:27:01 umbrel umbrel startup[24586]: Failed to start containers
Feb 14 10:27:01 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 10:27:01 umbrel systemd[1]: umbrel-startup.service: Failed with result 'exit-code'.
Feb 14 10:27:01 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Any insight from anyone as to how to solve this issue.?
thanks
There are dozen warnings saying disk is full…
