System CPU usage
Hi team,
UmbrelOS 1.1.1 is installed a few days now.
System CPU usage ist almost about 70%.
Bitcoin Core is using about 20% and Portainer less than 1 %.
What can i do to reduce the system usage?
Is that normal?
Thanks!
Is the Bitcoin still downloading/syncing the blockchain? That might use a lot of CPU.
How many other apps do you have running?
And how good is your CPU, because 70% of a weak one makes more sense.
Yes its still downloading.
But as the CPU usage is listed seperated for system and bitcoin i did not assume thats the problem.
