I upgraded to the latest version a couple of days ago. Everything worked fine. Today I open up umbrel and the lightning wallet is synchronizing… I stopped and restarted.
Before I research deeply on how to fix this (or panic) - is there a quick resolution for this?
I already explained here what could cause this slow sync after upgrade.
Also in troubleshooting manual I wrote about how to reset lnd.conf in case you put some line that it doesn’t let lnd to start.
Sometimes a reset of lnd.conf to default would make things to get faster.
If you recently did modifications into lnd.conf I suggest to go back to default and restart the node. Patiently wait to catch up.
