Been fighting my node for about 5 weeks now. I had added reindex=1 to resync, didnt realize that also needed to be deleted or it would resync on reboot. I believe I have that fixed now.
The issue now is the I get to about 10% then it will dump back to around 2%. I have been trying to sync this node for 5 WEEKS.
I reflashed SD as the last reflash was 0.3.8 or something.
At this point I dont really know what to do.
Couple things I notice that dont seem correct
262,591 of 534,578 blocks Why does it think theres only 534k blocks vs nealy 800k?
Also shows 10 peers Mempool 0 bytes hashrate 2 PH/s and Blockchain size 180GB
