Installed and started node on Rasp pi. Would like to reset. Added name and copied words but “one more thing” screen never came up. Computer shut down in middle of startup. Rebooted now just says Loading.
I have the same issue with my raspberry Pi setup. i installed the bitcoin app and started the sync. after some time i opened the app, but it shows loading. Even a restart of the app doesn’t help it still shows loading.
