Start script failing; port 8080 in use
Hi All,
I’m having a little trouble setting up my second node. Both running on Ubuntu, albeit different versions. The problem is with the node I’m trying to install on 21.04.
I’m getting a problem at start-up saying port 8080 is already in use when the lnd tries to come up. A quick look at Docker container ls shows the lncm/bitcoin deamon already has 8080. What am I missing?
Cheers!
I recommend to use a fresh installed Debian OS with all requisites for Umbrel as described on github Umbrel install instructions
Ended up being another service hogging the port.
