Ssd upgrade and OS migration
Hello,
I am running Umbrel on a M.2 ssd and need to upgrade it to a bigger one, any recommendations on how I can migrate the OS to the new disk?
Thank you all for your time!
The simple answer is clone it. Then expand the partition. Are you not able to mount an additional drive via USB or another method? What’s taking up all the room? Either way you choose to do it, you will expand your ninja skills.
Hello,
I just opened my GMKtec and there is another emptu M.2 slot so I could clone usinng something like Clonezilla?
The BTC blockchain gets bigger every day :smile:
I just cloned mine with etcher and expanded the partition with gparted.
no issues at all.
simple dd or any cloning software should work
