Log:
0.5.2
Flashed OS version
v0.5.2
Raspberry Pi Model
Revision : d03114
Serial : 1000000036121fd4
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=34.0’C
Throttling
throttled=0x0
Mem: 7.8G 122M 7.4G 8.0M 268M 7.6G
Swap: 0B 0B 0B
total: 1.6%
system: 1.6%
Memory monitor logs
/dev/root 59G 2.9G 53G 6% /
Startup service logs
– Logs begin at Tue 2022-11-01 21:17:01 UTC, end at Wed 2022-11-02 00:56:31 UTC. –
Nov 02 00:35:47 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Nov 02 00:35:47 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Nov 01 21:35:18 umbrel systemd[1]: Starting External Storage Mounter…
Nov 01 21:35:18 umbrel external storage mounter[483]: Running external storage mount script…
Nov 01 21:35:18 umbrel external storage mounter[483]: Found device “TOSHIBA External USB 3.0”
Nov 01 21:35:18 umbrel external storage mounter[483]: Blacklisting USB device IDs against UAS driver…
Nov 01 21:35:18 umbrel external storage mounter[483]: Checking USB devices are back…
Nov 01 21:35:18 umbrel external storage mounter[483]: Checking if the device is ext4…
Nov 01 21:37:32 umbrel external storage mounter[483]: Yes, it is ext4
Nov 01 21:37:32 umbrel external storage mounter[483]: Checking filesystem for corruption…
Nov 01 21:37:32 umbrel external storage mounter[483]: e2fsck 1.44.5 (15-Dec-2018)
Nov 01 23:53:15 umbrel external storage mounter[483]: Superblock last mount time is in the future.
Nov 01 23:53:15 umbrel external storage mounter[483]: (by less than a day, probably due to the hardware clock being incorrectly set)
Nov 01 23:53:15 umbrel external storage mounter[483]: Superblock last write time is in the future.
Nov 01 23:53:15 umbrel external storage mounter[483]: umbrel was not cleanly unmounted, check forced.
Nov 01 23:53:15 umbrel external storage mounter[483]: Pass 1: Checking inodes, blocks, and sizes
Nov 02 00:32:47 umbrel systemd[1]: umbrel-external-storage.service: Start operation timed out. Terminating.
Nov 02 00:32:47 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=killed, status=15/TERM
Nov 02 00:34:17 umbrel systemd[1]: umbrel-external-storage.service: State ‘stop-final-sigterm’ timed out. Killing.
Nov 02 00:34:17 umbrel systemd[1]: umbrel-external-storage.service: Killing process 1042 (fsck.ext4) with signal SIGKILL.
Nov 02 00:35:47 umbrel systemd[1]: umbrel-external-storage.service: Processes still around after final SIGKILL. Entering failed mode.
Nov 02 00:35:47 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘timeout’.
Nov 02 00:35:47 umbrel systemd[1]: Failed to start External Storage Mounter.
Nov 02 00:35:47 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Nov 02 00:35:47 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor Proxy logs
^C
