Sharing SSD by 2 PI
Can 2 nodes running on 2 raspberry pi’s share a single SSD?
If so, how?
Thanks,
Avi
Good idea, think is very original. You can work it if you are a developer, some of us may like it.
And we wonder why we have so many failed routes and offline peers… OMG
:rofl:
Yes you can share one drive as a network mounted storage.
I would not recommend sharing write access to the same files from two different devices though :slight_smile:
Although having different paths on the same drive should be fine. Also read only access for the same files from multiple devices should also be fine
