Second user can't login to Umbrel OS?
I thought I had everything working fine on my Umbrel until today when I tried to access the Umbrel admin page with a second user.
I have a Raspberry PI 5 setup running Umbrel OS so that I can share an external USB drive both locally and remotely with two people. One of those people being me the admin user of Umbrel.
I have all of that setup and working for myself but I just added a user to the Tailnet on tailscale.com (I’m very new to all of this so hopefully I’ve done that all correctly) but when they try to access the Umbrel admin page they can do so when Tailscale is connected but only by using the Tailscale magicDNS URL or IP address but not http://umbrel.local. If they turn off Tailscale then only the http://umbrel.local address works which is kind of expected however I’ve no idea why that local address doesn’t work when Tailscale is connected as it works fine on my computer.
Next up and the main issue though is that when they can get to the admin panel and it shows the two user accounts asking them to login if they put their password in and click login then they get a page that says :
Unable to check your Umbrel right now. We’ll try again automatically. Check that it’s powered on and connected to your network.
The Umbrel is powered on and connected to the network and working fine as I can use it from my own devices but this one computer owned by the second user can’t get into the admin panel at all.
I’ve checked there are no firewalls or VPNs active on the Mac with the issue and tried in a private browser window on three different browsers.
The user also has been given access to all apps in the user settings of Umbrel although I actually don’t want them to have access to all of them but just did that for testing incase you can’t login if no apps are given access and I also turned on USB storage, network devices and allow file sharing incase those being off has any impact on it working but after all that they still can’t login and get that error every time.
I also tried logging into the new users account on my own machine and it logs in just fine. It’s literally just when using the other computer that they can’t login to the admin panel.
I’m fresh out of ideas now so any help anyone could give would be massively appreciated here as I’m exceptionally new to all of this and don’t fully understand it all but have got it all working so just thought it really should work on this second computer but apparently not :frowning:
Thanks for any help with this,
Mark
P.S. I’ve just noticed that the second computer when connected to Tailscale can’t access http://www.apple.com or Google Mail but does access the Google search site and comes up with a This site can’t be reached message in the browser. Google works fine and other sites too though obviously I can’t check every site but it does seem odd that doesn’t want to work when Tailscale is connected?
I don’t think this has anything to do with the second user’s account. You already showed that by logging in as them on your own computer and it worked fine. It’s something about how that one Mac reaches the Umbrel.
As far as I know, the password part actually goes through fine. Right after login, the dashboard opens a live connection back to the Umbrel to load everything, and if that connection can’t get through from the Mac you land on that “Unable to check your Umbrel right now” screen. So it’s really a network problem on that Mac, and the apple.com and Gmail thing you spotted points the same way.
First thing I’d check is the exit node. On that Mac, click the Tailscale icon in the menu bar and look at Exit Node. If it’s set to anything other than None, switch it to None. With an exit node on, all of the Mac’s internet goes through another device on your tailnet, and it also cuts off the local network. That would explain umbrel.local not working with Tailscale on, and some sites not loading.
If it’s already None, have a look at the DNS page in the Tailscale admin console (Tailscale). If you added a custom nameserver there with “Override local DNS” turned on, try turning that off and see if apple.com and Gmail start loading on that Mac.
Then try logging in again on that Mac. If you still get the same screen, click “Technical details” under the message and post what it says here. That should show what’s actually failing.
Also, you can take back the app access and the other permissions you turned on for testing. As far as I know a user doesn’t need any apps shared with them to be able to log in.
