Running Bitcoin-Knots on Pi4
Just want to let everyone know that knots runs perfectly on the Pi-4, you just have to run the commands from the terminal instead of the GUI to get the apps installed. All the integrated apps such as ElectRS and BTC RPC explorer work fine too, install by using the terminal commands.
It’s been up for over 30days on my Pi4 without any issues.
Great to hear Tony. I have Knots running on a Pi5 with only Datum installed and its a little laggy so maybe I need to just run it from the command line instead of GUI.
