Good day legend,
I tried to open a watch tower, unfortunately I set the fee to 2 sats/vb this actually reckt my all node and I could not restart it.
I ssh to the config but you regenerate the config which by the way I get it for people that doesn’t know what they doing but in that case I would really love to be able to swap fee for example so I wouldn’t have to do what I did next.
As my node was not running anymore I add to delete the Lightning node app. This was a mistake… x.com
So when they asked if I had channel open I said YES
Then I saw the recovery file or my back up so I press recover and everything got force close… Really not what I wanted.
So my question is could I just press BACK instead of pressing the back up file? Like see on this pic:
Would this could have saved my channels? Or not when you are uninstalling the app you have to force close everything?
Thank you
