Rebalancing two Channels
Hello, I tried to rebalance 2 channels. I done it in Thunderhub, but the problem is that it doesn’t load completly. It still loading and loading. And I see that my lightning wallet balance still swapping about those sats I choose, It goes up and down very 2 seconds and don’t stop. Whats this?
Can somebody help, it looks like a bug or something. How can I stop it? Its ok when the rebalancing don’t work but that swapping is annoying.
Thanks
Looks like you have shity peers that do not have enough liquidity to make that swap or you set wrong fees.
Try to use RTL for circular rebalancing, sometimes works better.
Thanks for your tip! It worked immediately!
