Hello Evrybody,
i got my bitcoin node on Umbrel and it(s cool,
can we create a new node with the Ravencoin Project directly on Umbrel
thanks to all
Hello Evrybody,
thanks to all
Totally useless. Another bloatware.
Umbrel is by design a private node, behind Tor.
That means you will have at maximum 10-11 peers (in and out) for syncing your blockchain.
For running a full visible bitcoin node, you need:
THIS IS NOT MEANT TO HAPPEN WITH UMBREL NODES! In special with the plethora of RPis machines that barely handle 10 peers and a LN node with 100 channels…
Guys, start learning about how Bitcoin networks works before coming with crazy useless ideas.
hello
ok
thanks for u response
i understand
thanks
