Hi there.
Some days ago my Umbrel node stopped to respond at onion address.
When trying to restart the node, it stuck in a message “starting Umbrel…”.
Any ideas on how to go over this?
Thank in advance.
Hi there.
Thank in advance.
read
http://community.umbrel.com/t/umbrel-troubleshooting-guide/
and also generate debug logs and see what happen. Otherwise… nobody have a crystal ball to know what you did or what is happening inside your node.
Thank you DarthCoin.
Beginning with re-flashing mSD card.
It is taking a long time to re-start RasPi. It stucks at:
[ 147.325990] random: crng init done
Let’s wait.
The problem is the Low Voltage Warning in the Raspberry Pi.
The start process ends with this message:
Under-voltage detected! (0x00050005)
Though I’m using the charger provided by the Raspi vendor: OUTPUT 5.0V 3.0A.
Anyone dealed with this?
Thanks in advance.
What do you have plugged in to it? I recall reading that 1 SSD is fine but if you want to hook up 2 unpowered SSDs or HDDs it starts to have power issues
1 HDD (and micro HDMI just to display start process.
The strange thing is that my Raspi 4 has been running for one and a half year with this charger.
I’ve ordered an “official” one just to make sure it is not a charger issue.
Good approach. Please submit updates
Voltage problem solved with official charger. Now my node doesn’t want to start.
I will open a new isse.
