I just ran an sudo apt update && sudo apt upgrade and it was there to be updated, better to advise all the users, unless an update of umbrel is coming very soon.
I assume that the patch for this will be integrated into the next Umbrel release. Fingers crossed.
If we update the patch manually through apt update, does that complicate things when the Umbrel update rolls around?
Not too much to worry. Guys don’t be so paranoia. This vulnerability is a threat ONLY when is used that “kit”.
In Umbrel is NOT used.
Stay put, until next Umbrel update is done. Don’t do much harm to your node than is necessary.
