hi
i have a bitaxe connected to my umbrel server with public pool.
after the update to version 1.4 it does not connect to umbrel.
i can’t get it to stay on Stratum Host and it immediately jumps to Fallback Stratum Host.
this is the message that the public pool log shows:
public-pool_server_1 | Error getmininginfo Error: ESOCKETTIMEDOUT
public-pool_server_1 | block height change
public-pool_server_1 | Killing dead clients
public-pool_server_1 | Deleting statistics
public-pool_server_1 | Deleted 0 old statistics
any suggestions ??
thanks
Same issues here running a Canaan Avalon Mini 3. Avalon shows hashing, but pool shows nothing. I’ve restarted the publicpool app several times, but no success. Any help is appreciated.
In my case, mysteriously, it started working normally. I just assigned a fixed IP address on the router to my Raspi4.
Although sometimes I have to restart public-pool because it jumps to the alternate server.
In my case, it’s a bitaxe gamma.
Same here, not showing any work.
I hope someone from the Umbrel or Public-Pool team, or even an advanced user, reads these posts and can help us with this.
On another note, in another matter (related to a server update), it was an advanced user who solved the problem for us.
I was able to connect to my Umbrel Home (version 1.4) by setting a static IP address in my router, so it’s always the same for Umbrel. I then did the same for each of my miners. With every mining device and Umbrel Home now on a static IP, I connect to my Umbrel Home Public Pool using my IP address like this example:
For BitAxe’s: Stratum URL: 192.168.0.229 Port: 2018 Stratum User: BTC address.worker
for Avalon’s: Pool Address: stratum+TCP://192.168.0.229:2018 Worker: BTC address.worker
The guidance from Public Pool saying to use “stratum+tcp://umbrel.local:2018” did not work for me. IP addresses do work, and all miners are hashing and pool information matches.
Hope this helps.
yes ive ran across some miners that want the URL in one field and the port in another “no stratum” lucky miner does it.. “underrated miners for $”
I would open some ports on your router.. ??? try them all its not getting the info its asking for.. ive seen it but it luckily bought up "in a second or 2. rarely have I seen that error tho..
I think it was a problem with the router. I assigned the Umbrella server a fixed IP address on the router, and everything is working fine. Thanks.
Was getting this same error, a lot. After trying a few things, the fix for me was increasing the - BITCOIN_RPC_TIMEOUT=10000 to 20000. Unverified, but I think this can be up to a max of 120000.
This setting can be found in ~/umbrel/app-data/public-pool/docker-compose.yml
Hope it helps someone
