I have problems accessing umbrel.local.
After rebooting or restarting the Raspy, access works for a moment. Afterwards, however, the dashboard can no longer be accessed (neither locally nor via Tor).
On the advice of a member in the Telegram group, I reflashed the mSD. This fixed the problem but only for a short time. I also have tried the other USB Port for the SSD.
My node is a Raspy 4 with a 1TB SSD. I gave the node a fixed IP address. It has the latest version (v.0.3.14) installed.
The troubleshoot logs look good in my opinion. The only thing I found was the following message in the dsmeg.log file.
Hey, @Badoup! The dmesg log looks like a non-issue. I can see the same on my Umbrel too. From Raspberry Pi’s forum “It appears that the driver looks for a board-specific firmware blob (which doesn’t exist), and then falls back to a more generic one (which does).”
So the issue must be something else. When the dashboard is no longer available, can you still SSH into your Umbrel? If so, can you run the debug script (sudo ~/umbrel/scripts/debug) and DM us the output using pastebin?
I’m also having this issue. umbrel.local is unavailable. When I reboot it becomes available but then after a few days it shuts down again. I ran ~/umbrel/scripts/debug but didn’t see anything notable.
==== Result ====
From your logs it appears that you’re on 0.3.10, and the connectivity issue was fixed in 0.3.14 so it’s an easy fix — just update to the latest Umbrel version and you’d be good!
Hi All - I’m having a similar issue. After running my node for the past week and having no issues I came home this afternoon to find that I could no longer access umbrel.local. After restarting a few times I was able to access the dashboard through the IP address, but I did notice that it was down for about 4 hours as I was about 4 hours behind on blocks. Any ideas?
I have similar issue described here.
I am running with version 0.4.0.
I noticed this as suddenly Umbrel started to run really hot and my case temperature controlled fan started to spin. Normally it won’t.
I could not access Umbrel with local DNS name or with IP. I could however reach it with TOR. I restarted Umbrel trough that and after that local connection started to work again.
