Problem connecting to my umbrel
I cant connect to my server every few days or so i need to restart it to connect it do you have any ideas on how to fix this? I have used umbral.local and the ip address that shows up in angry Ip scanner to try to connect to the server.
Have a look at this - Umbrel server (x86) keeps disconnecting after 2-3 days
TLDR; Update to the latest Beta version, it seems to have sorted the issue for me for now.
Thank you so much I will try that.
