I have successful installed the Plex app and are now trying to add some movies to Plex library. First I tried to add some movies to the Videos folder in the Files app, but could not figure out how to select it from Plex lib. Then I added the movies to the Downloads, in the Files app
When selecting the location, during adding the Library in Plex, I can see the (a) downloads folder, but not a Videos folder. How can I select the Videos folder?
Hi! I found a solution.
You need to edit file /home/umbrel/umbrel/app-data/plex/docker-compose.yml using the terminal or ssh. Volumes should look like this
volumes:
- ${APP_DATA_DIR}/data/config:/config
- ${APP_DATA_DIR}/data/transcode:/transcode
- ${UMBREL_ROOT}/home/Downloads:/download
# Just add the following line:
- ${UMBREL_ROOT}/home/Videos:/videos
You can even add other folders such as external devices (which was my case) adding:
- ${UMBREL_ROOT}$/external:/external.
Hope it helped.
Thank You very much for the reply. I will try to update my installation
