Hi, I’ve been searching the web but couldn’t find any tutorial for Jellyfin (or Plex or any other streaming app of your choice).
I’ve tried to upload files with File Browser app from the Umbrel store but these files don’t appear anywhere so I assume their readable only by File Browser. I suppose I’ll need some other file manager app but couldn’t find any.
My understanding is there is no upload through the app. Instead, you point it to the folder(s) that contain the media. This is located at Libraries | Jellyfin.
If they are not located on your server, uploading would be done in two ways. The first would be to put them on an external drive, then plug it in and point it to the device. The other way is to ssh into Umbrel and copy the files.
When I did a google search, their AI had a good answer. My search was: Google Search
