Pihole DHCP server not working
I just installed pi-hole and that works, but when i enable DHCP Server it doesn’t give any ipaddress to the clients.
I think it can have something to do with the ipaddress i changed for Umbrel from dhcp to static. I changed the ipaddress in dhcpcd.conf.
sudo nano /etc/dhcpcd.conf
After that i installed pi-hole and that works, but when i enable DHCP server it doesn’t work.
when i look at the network overview i see 2 strange ipaddresses which i don’t understand. Can someone perhaps explain what the addresses are for?
kind regards,
Marco
did you ever get your Pi-hole DHCP server working?
Wow 2 years ago… , yeah its working now. I dont use imbrel but pihole is running. I think i just reinstalled and read some other forums.
Sorry, dont know anymore then that.
Gl
