Pi-Hole - Unable to add and update blocklists
Hey,
i tried to add Blocklists in Pi-Hole. But it doesn´t work. This message appears:
Error, something went wrong!
While executing: attempt to write a readonly database
Added 0 out of 1 adlists
When I try to update the Gravity (list of blocked domains) I get this message:
[✗] DNS resolution is currently unavailable
[✗] DNS resolution is not available
Is there any way to make this happen?
Thanks in advance
I solved the problem.
I deleted the partitions and formated the SD-Card with exFat. Than I flashed the Card with the latest Umbrel Version.
Now it works…
Hey, what do you mean by “deleted the partitions”. I have the same error and only flashing the SD Card does not help :frowning:
Since ne latest Update pi-hole is working fine. :ok_hand:
