How do I find out my username and password if I didn’t set it,and the username and password when logging in to the dashboard doesn’t fit
If you are talking about an app from the Umbrel Appstore, search for it there, and it will be in the right pane. Alternatively, it can be found as a separate item in the application’s context menu on the main screen.
