Hello
I have been trying to make my rasbery py umbrel to work for a few months now. Tryed many things that worked other that had little to no result. Finally decided to restart the node from scratch. By that I mean I reformated both hard drive and SD card. My prblem now is that I dont even get to download the blockchain.
Harware:
- Kit Raspberry Pi4 8gb
- Seagate Expantion 1TB
- Previous errors got me to buy an orginal power suply.
- I decided to keep the case fan connected (Umbrel was not loading with it, that was solved by disconecting it but then the heat was too much, hoping that the power suply can handle it…)
From what I can tell umbrel is having a hard time connecting to several sources. Both my computer and Umbrel are conected to the same switch and internet is working on my computer (even with links that are refused in the logs). The dashboard is sluggish but I think that may be due to timeouts…
I hope I provided all the info that is needed, let me know if I let anything slip!
I’m ataching my current logs and would apretiate some help on how to move forward.
umbrel-1635259813765-debug.log (30.8 KB)
