If you’re looking to open channels to nodes that run El Salvador’s LN infra:
I keep getting this error when opening a channel with Chivo’s node
Unable to connect to peer, socks connect tcp X.X.X.X:9050->X.X.X.X:9735: unknown error general SOCKS server failure
Same here. Does anyone know the possible reason?
Did a bit of reading, I am wondering if the problem with the Chivo node has something to do with Tor running on Umbrel and Tor not running on the Chivo node.
They probably need to open a peer to you before you can open to them.
