When I go the app store to attempt to download a new app, I click “install” and nothing happens. No, it’s not a networking issue as I can easily open apps I already have. Any ideas?
Can you check the logs and share them here? That might help figure out what’s going wrong.
Sometimes, a simple restart fixes the issue. Have you tried that already?
Sorry. I’m still new to this. I downloaded the log however I don’t know how to share it.
Feb 17 23:05:44 umbrel umbreld[610]: [apps ] Installing app lightning-terminal
Feb 17 23:05:44 umbrel umbreld[610]: [apps ] Setting up data directory for lightning-terminal
Feb 17 23:05:45 umbrel umbreld[19432]: time=“2025-02-17T23:05:45Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
Feb 17 23:05:45 umbrel umbreld[19432]: Container tor_proxy Running
Feb 17 23:05:45 umbrel umbreld[19432]: Container auth Running
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.167336374Z” level=warning msg=“Error getting v2 registry: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.167393337Z” level=info msg=“Attempting next endpoint for pull after error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.170465448Z” level=warning msg=“Error getting v2 registry: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.170503133Z” level=info msg=“Attempting next endpoint for pull after error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.172281170Z” level=warning msg=“Error getting v2 registry: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.172322281Z” level=info msg=“Attempting next endpoint for pull after error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.173426800Z” level=error msg=“Handler for POST /images/create returned error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel umbreld[610]: [apps ] [error] Failed to install app lightning-terminal: (HTTP code 500) server error - Get “https://registry-1.docker.io/v2/”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.175936429Z” level=error msg=“Handler for POST /images/create returned error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution"
Feb 17 23:05:45 umbrel dockerd[381]: time=“2025-02-17T23:05:45.177854189Z” level=error msg=“Handler for POST /images/create returned error: Get "https://registry-1.docker.io/v2/\”: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution
