Node stuck on loading log in page
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Dec 9 03:53:33 2023 from fe80::1b0a:c5d0:b3b7:82c3%eth0
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/debug
[sudo] password for umbrel:
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : c03112
Serial : 1000000092127440
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=54.5’C
Throttling
throttled=0x80000
Mem: 3.8G 2.1G 209M 190M 1.5G 1.4G
Swap: 4.1G 1.7G 2.4G
total: 54.8%
system: 26.5%
bitfeed: 14%
mempool: 10.1%
bitcoin: 2.9%
electrs: 1.3%
Memory monitor logs
2024-01-11 05:29:30 Warning memory usage at 91%
2024-01-11 06:47:32 Warning memory usage at 91%
2024-01-11 16:25:46 Warning memory usage at 91%
2024-01-12 10:12:08 Warning memory usage at 91%
2024-01-12 20:44:21 Warning memory usage at 91%
2024-01-13 08:10:34 Warning memory usage at 91%
2024-01-23 12:34:14 Warning memory usage at 91%
2024-01-27 20:24:14 Warning memory usage at 91%
2024-02-02 09:44:54 Warning memory usage at 91%
2024-02-03 16:06:30 Warning memory usage at 91%
/dev/root 30G 30G 0 100% /
/dev/sda1 916G 916G 0 100% /home/umbrel/umbrel
Startup service logs
– Logs begin at Fri 2024-04-12 13:19:16 UTC, end at Fri 2024-04-12 13:38:43 UTC. –
– No entries –
External storage service logs
– No entries –
– No entries –
Karen logs
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/6636’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/1189’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/12179’: No space left on device
GotGot signal: change-password
New password: Retype new password: passwd: Authentication token manipulation error
passwd: password unchanged
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/30445’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/30921’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/29138’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/29814’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/25708’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/15464’: No space left on device
Docker containers
NAMES STATUS
bitfeed_web_1 Up 3 months
bitfeed_app_proxy_1 Up 3 months
bitfeed_api_1 Up 3 months
bitcoin_server_1 Up 4 months
electrs_app_1 Up 4 months
bitcoin_tor_1 Up 4 months
bitcoin_bitcoind_1 Restarting (1) 10 days ago
bitcoin_app_proxy_1 Up 4 months
bitcoin_i2pd_daemon_1 Up 2 months
mempool_app_proxy_1 Up 4 months
mempool_mariadb_1 Up 4 months
mempool_api_1 Up 4 months
mempool_web_1 Up 4 months
electrs_tor_1 Up 4 months
electrs_app_proxy_1 Up 4 months
electrs_electrs_1 Restarting (1) 10 days ago
nginx Up 4 months
tor_proxy Up 4 months
manager Up 4 months
dashboard Up 4 months
auth Up 4 months
Umbrel logs
Attaching to manager
manager | at authenticate (/app/node_modules/passport/lib/middleware/authenticate.js:367:7)
manager | at jwt (/app/middlewares/auth.js:150:5)
manager | at Layer.handle [as handle_request] (/app/node_modules/express/lib/router/layer.js:95:5)
manager | at next (/app/node_modules/express/lib/router/route.js:137:13)
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:30 GMT] “POST /v1/account/refresh HTTP/1.0” 401 13 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:31 GMT] “GET /v1/account/registered HTTP/1.0” 200 19 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | [LND Seed Migration] Checking if seed should be migrated…
manager | [LND Seed Migration] Lightning app not installed, skipping migration.
manager | ::ffff:10.21.21.2 - admin [Wed, 10 Apr 2024 13:17:34 GMT] “POST /v1/account/login HTTP/1.0” 200 273 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | (node:28) UnhandledPromiseRejectionWarning: Error: connect ECONNREFUSED 127.0.0.1:3005
manager | at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
manager | (node:28) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v25.2.1 Documentation). (rejection id: 34)
manager | (node:28) UnhandledPromiseRejectionWarning: Error: ENOSPC: no space left on device, write
manager | (node:28) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v25.2.1 Documentation). (rejection id: 35)
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:34 GMT] “GET /v1/account/info HTTP/1.0” 200 128 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:34 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:35 GMT] “GET /v1/system/is-umbrel-os HTTP/1.0” 200 4 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 10 Apr 2024 13:17:35 GMT] “GET /v1/account/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36”
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Apr 01 21:51:41.000 [notice] While not bootstrapping, fetched this many bytes: 28909315 (consensus network-status fetch); 56327 (authority cert fetch); 104730780 (microdescriptor fetch)
tor_proxy | Apr 01 21:51:41.000 [notice] Average packaged cell fullness: 75.552%. TLS write overhead: 5%
tor_proxy | Apr 02 03:51:41.000 [notice] Heartbeat: Tor’s uptime is 115 days 0:00 hours, with 1 circuits open. I’ve sent 123.43 MB and received 270.75 MB. I’ve received 478 connections on IPv4 and 0 on IPv6. I’ve made 2761 connections with IPv4 and 0 with IPv6.
tor_proxy | Apr 02 03:51:41.000 [notice] While bootstrapping, fetched this many bytes: 701642 (consensus network-status fetch); 14104 (authority cert fetch); 12455389 (microdescriptor fetch)
tor_proxy | Apr 02 03:51:41.000 [notice] While not bootstrapping, fetched this many bytes: 28974940 (consensus network-status fetch); 56327 (authority cert fetch); 104730780 (microdescriptor fetch)
tor_proxy | Apr 02 03:51:41.000 [notice] Average packaged cell fullness: 75.550%. TLS write overhead: 5%
tor_proxy | Apr 02 09:51:41.000 [notice] Heartbeat: Tor’s uptime is 115 days 6:00 hours, with 0 circuits open. I’ve sent 123.62 MB and received 272.14 MB. I’ve received 479 connections on IPv4 and 0 on IPv6. I’ve made 2767 connections with IPv4 and 0 with IPv6.
tor_proxy | Apr 02 09:51:41.000 [notice] While bootstrapping, fetched this many bytes: 701642 (consensus network-status fetch); 14104 (authority cert fetch); 12455389 (microdescriptor fetch)
tor_proxy | Apr 02 09:51:41.000 [notice] While not bootstrapping, fetched this many bytes: 29027185 (consensus network-status fetch); 56327 (authority cert fetch); 105917272 (microdescriptor fetch)
tor_proxy | Apr 02 09:51:41.000 [notice] Average packaged cell fullness: 75.583%. TLS write overhead: 5%
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_tor_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1, bitcoin_i2pd_daemon_1
i2pd_daemon_1 | 19:34:55@475/error - Tunnels: Can’t select next hop for M7gmwV-KRgCB~Xq89QmROPNc9NL~LNKzkxbjr0uveFo=
i2pd_daemon_1 | 19:34:55@475/error - Tunnels: Can’t create inbound tunnel, no peers available
i2pd_daemon_1 | 19:34:55@475/error - Tunnels: Can’t select next hop for VeXCyu9jnJRSimj22OjQ4OA~BJrKeTbWQ17OvOohvSY=
i2pd_daemon_1 | 19:34:55@475/error - Tunnels: Can’t create outbound tunnel, no peers available
i2pd_daemon_1 | 19:34:55@475/error - Tunnels: Can’t select next hop for cm5LTOu7yUMZaSSMIorWPZGtqDBztzgO9wQyzW64unU=
bitcoind_1 | Error: Settings file could not be written:
bitcoind_1 | - Error: Unable to open settings file /data/.bitcoin/settings.json.tmp for writing
app_proxy_1 | Validating token: 5a01482c4fe5 …
app_proxy_1 | Validating token: 2407b0d2084c …
app_proxy_1 | Error: connect EHOSTUNREACH 10.21.21.4:3006
app_proxy_1 | at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16) {
server_1 | [WARNING] Invalid JSON detected in /bitcoin/.bitcoin/settings.json. Overwriting with empty JSON.
server_1 | settings.json backup created at /bitcoin/.bitcoin/settings.json.backup.1711314422374
server_1 | settings.json backup created at /bitcoin/.bitcoin/settings.json.backup.1711314482432
server_1 | settings.json backup created at /bitcoin/.bitcoin/settings.json.backup.1711314542470
server_1 | settings.json backup created at /bitcoin/.bitcoin/settings.json.backup.1711314602528
server_1 | settings.json backup created at /bitcoin/.bitcoin/settings.json.backup.1711314662574
tor_1 | Apr 10 15:52:49.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 10 15:52:49.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 10 16:02:38.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 10 16:02:38.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 10 16:25:18.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 10 16:25:18.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 10 16:26:04.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 10 16:26:04.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 10 16:35:42.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 10 16:35:42.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
bitfeed
Attaching to bitfeed_web_1, bitfeed_app_proxy_1, bitfeed_api_1
api_1 | :connection_error
api_1 | :error: :ehostunreach
api_1 | 02:30:18.206 [error] :host: 10.21.21.8
api_1 | :port: 28335
api_1 | 02:30:18.207 [error] :host: 10.21.21.8
api_1 | :port: 28333
app_proxy_1 | [HPM] WebSocket error: Error: read ECONNRESET
app_proxy_1 | at TCP.onStreamRead (node:internal/stream_base_commons:217:20) {
app_proxy_1 | errno: -104,
app_proxy_1 | code: ‘ECONNRESET’,
app_proxy_1 | syscall: ‘read’
app_proxy_1 | }
web_1 | 2024/03/21 19:58:41 [warn] 36#36: *87 an upstream response is buffered to a temporary file /var/cache/nginx/proxy_temp/8/02/0000000028 while reading upstream, client: 10.21.0.7, server: client, request: “GET /api/block/0000000000000000000203330f03dfbd1f8f2ac3cc37c4f33e606769f81162d1 HTTP/1.1”, upstream: “http://10.21.0.6:8315/api/block/0000000000000000000203330f03dfbd1f8f2ac3cc37c4f33e606769f81162d1”, host: “umbrel.local:8314”, referrer: “http://umbrel.local:8314/”
web_1 | 10.21.0.7 - - [21/Mar/2024:19:58:41 +0000] “GET /api/block/0000000000000000000203330f03dfbd1f8f2ac3cc37c4f33e606769f81162d1 HTTP/1.1” 200 768912 “http://umbrel.local:8314/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “::ffff:192.168.1.25”
web_1 | 2024/03/21 20:12:06 [warn] 36#36: *89 an upstream response is buffered to a temporary file /var/cache/nginx/proxy_temp/9/02/0000000029 while reading upstream, client: 10.21.0.7, server: client, request: “GET /api/block/00000000000000000002829be33003a067c19fe3fd7b6d427b9fb2d2dacc73c7 HTTP/1.1”, upstream: “http://10.21.0.6:8315/api/block/00000000000000000002829be33003a067c19fe3fd7b6d427b9fb2d2dacc73c7”, host: “umbrel.local:8314”, referrer: “http://umbrel.local:8314/”
web_1 | 10.21.0.7 - - [21/Mar/2024:20:12:06 +0000] “GET /api/block/00000000000000000002829be33003a067c19fe3fd7b6d427b9fb2d2dacc73c7 HTTP/1.1” 200 742989 “http://umbrel.local:8314/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “::ffff:192.168.1.25”
web_1 | 2024/03/21 20:16:32 [warn] 36#36: *91 an upstream response is buffered to a temporary file /var/cache/nginx/proxy_temp/0/03/0000000030 while reading upstream, client: 10.21.0.7, server: client, request: “GET /api/block/0000000000000000000356d53aaf7292bcb701ca72231ff8a40a1821a1f8ad2b HTTP/1.1”, upstream: “http://10.21.0.6:8315/api/block/0000000000000000000356d53aaf7292bcb701ca72231ff8a40a1821a1f8ad2b”, host: “umbrel.local:8314”, referrer: “http://umbrel.local:8314/”
web_1 | 10.21.0.7 - - [21/Mar/2024:20:16:32 +0000] “GET /api/block/0000000000000000000356d53aaf7292bcb701ca72231ff8a40a1821a1f8ad2b HTTP/1.1” 200 562988 “http://umbrel.local:8314/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “::ffff:192.168.1.25”
web_1 | 2024/03/21 20:23:02 [warn] 36#36: *93 an upstream response is buffered to a temporary file /var/cache/nginx/proxy_temp/1/03/0000000031 while reading upstream, client: 10.21.0.7, server: client, request: “GET /api/block/00000000000000000002a6a426c4324306c6116501bb217eaa7605d5ca6f5ad1 HTTP/1.1”, upstream: “http://10.21.0.6:8315/api/block/00000000000000000002a6a426c4324306c6116501bb217eaa7605d5ca6f5ad1”, host: “umbrel.local:8314”, referrer: “http://umbrel.local:8314/”
web_1 | 10.21.0.7 - - [21/Mar/2024:20:23:03 +0000] “GET /api/block/00000000000000000002a6a426c4324306c6116501bb217eaa7605d5ca6f5ad1 HTTP/1.1” 200 643149 “http://umbrel.local:8314/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “::ffff:192.168.1.25”
web_1 | 10.21.0.7 - - [21/Mar/2024:20:27:34 +0000] “GET /api/block/00000000000000000000d2e0af4ced4d33c7499caf6eac77826b439365d2f771 HTTP/1.1” 200 706832 “http://umbrel.local:8314/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “::ffff:192.168.1.25”
web_1 | 10.21.0.7 - - [21/Mar/2024:20:30:25 +0000] “GET /ws/txs HTTP/1.1” 101 50530878 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36” “-”
electrs
Attaching to electrs_app_1, electrs_tor_1, electrs_app_proxy_1, electrs_electrs_1
app_1 | > umbrel-electrs@1.0.1 dev:backend
app_1 | > npm run start -w umbrel-electrs-backend
app_1 |
app_1 |
app_1 | > umbrel-electrs-backend@0.1.12 start
app_1 | > node ./bin/www
app_1 |
app_1 | Sat, 09 Dec 2023 03:52:23 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:28:9
app_1 | Sat, 09 Dec 2023 03:52:23 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1 | Listening on port 3006
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.4:3006
app_proxy_1 | Waiting for 10.21.22.4:3006 to open…
app_proxy_1 | Electrs is now ready…
app_proxy_1 | Listening on port: 2102
electrs_1 | 0: failed to open DB: /data/db/bitcoin
electrs_1 | 1: IO error: No space left on deviceWhile appending to file: /data/db/bitcoin/352772.sst: No space left on device
electrs_1 | Starting electrs 0.9.10 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.9.10)”, signet_magic: 3652501241, args: }
electrs_1 | [2024-04-02T11:56:22.426Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2024-04-02T11:56:22.426Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
tor_1 | Apr 11 18:43:05.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 11 18:43:05.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 11 18:50:24.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 11 18:50:24.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 11 19:00:39.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 11 19:00:39.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 11 19:28:33.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 11 19:28:33.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
tor_1 | Apr 11 19:29:04.000 [warn] Error writing to “/tmp/.tor/state”: No space left on device
tor_1 | Apr 11 19:29:04.000 [warn] Unable to write state to file “/tmp/.tor/state”; will try again later
mempool
Attaching to mempool_app_proxy_1, mempool_mariadb_1, mempool_api_1, mempool_web_1
app_proxy_1 | }
app_proxy_1 | [HPM] Upgrading to WebSocket
app_proxy_1 | }
app_proxy_1 | [HPM] Client disconnected
api_1 | Apr 11 18:35:21 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:36:27 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:37:33 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:38:39 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:39:45 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:40:51 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:41:58 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:43:04 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:44:10 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
api_1 | Apr 11 18:45:16 [94] WARN: runMainLoop error: connect EHOSTUNREACH 10.21.21.8:8332. Retrying in 60 sec.
mariadb_1 | 2023-12-09 3:52:05 0 [Note] Added new Master_info ‘’ to hash table
mariadb_1 | 2023-12-09 3:52:05 0 [Note] mysqld: ready for connections.
mariadb_1 | Version: ‘10.5.12-MariaDB-1:10.5.12+maria~focal’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
mariadb_1 | 2023-12-09 3:52:05 3 [Warning] Aborted connection 3 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-12-09 3:52:05 4 [Warning] Aborted connection 4 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.26’ (This connection closed normally without authentication)
mariadb_1 | 2023-12-09 3:52:07 0 [Note] InnoDB: Buffer pool(s) load completed at 231209 3:52:07
mariadb_1 | 2024-03-25 1:53:52 6 [Warning] Aborted connection 6 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got timeout reading communication packets)
mariadb_1 | 2024-03-25 1:53:52 5 [Warning] Aborted connection 5 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got timeout reading communication packets)
mariadb_1 | 2024-03-30 11:54:22 7 [Warning] Aborted connection 7 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got timeout reading communication packets)
mariadb_1 | 2024-04-06 11:54:43 8 [Warning] Aborted connection 8 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got timeout reading communication packets)
==== Result ====
The temperature of your Raspberry Pi is too high. We recommend either using a case that lowers the temperature of your Pi or a case with a builtin fan.
umbrel@umbrel:~ $
