I have been redownloading the BTC ledger so that I can use my node and it got stuck at 99.6%. I tried a few things ( the download took like 4 weeks) and still can’t get it to work.
Hi, I might had the same problem. The solution steps described in my topic solved the problem.
I have a same issue, tried your solution but it didn’t work for me?
You used the terminal to enter the commands?
Yes I used the terminal as described by strategicBTC in my topic.
