I ran the ~/umbrel/scripts/debug --upload command and this is the outcome. Any ideas?
Linux umbrel 5.10.17-v8+ #1421 SMP PREEMPT Thu May 27 14:01:37 BST 2021 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Aug 3 00:27:23 2021 from 192.168.0.192
umbrel@umbrel:~ $ ~/umbrel/scripts/debug --upload
0.3.14
Flashed OS version
v0.3.12
Raspberry Pi Model
Revision : d03114
Serial : 100000009b7a3856
Firmware
May 27 2021 14:02:15
Copyright © 2012 Broadcom
Temperature
temp=46.2’C
Throttling
throttled=0x0
Mem: 7.8G 134M 7.1G 16M 554M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.7%
system: 1.7%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2021-08-03 00:42:50 Memory monitor running!
2021-08-03 00:43:01 Memory monitor running!
2021-08-03 00:43:15 Memory monitor running!
/dev/root 59G 3.1G 53G 6% /
/dev/sda1 916G 502G 368G 58% /home/umbrel/umbrel
Startup service logs
Aug 03 00:43:25 umbrel umbrel startup[22596]: resp = self.send(prep, **send_kwargs)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 646, in send
Aug 03 00:43:25 umbrel umbrel startup[22596]: r = adapter.send(request, **kwargs)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 498, in send
Aug 03 00:43:25 umbrel umbrel startup[22596]: raise ConnectionError(err, request=request)
Aug 03 00:43:25 umbrel umbrel startup[22596]: requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
Aug 03 00:43:25 umbrel umbrel startup[22596]: During handling of the above exception, another exception occurred:
Aug 03 00:43:25 umbrel umbrel startup[22596]: Traceback (most recent call last):
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/bin/docker-compose”, line 10, in
Aug 03 00:43:25 umbrel umbrel startup[22596]: sys.exit(main())
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 81, in main
Aug 03 00:43:25 umbrel umbrel startup[22596]: command_func()
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 200, in perform_command
Aug 03 00:43:25 umbrel umbrel startup[22596]: project = project_from_options(’.’, options)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 70, in project_from_options
Aug 03 00:43:25 umbrel umbrel startup[22596]: enabled_profiles=get_profiles_from_options(options, environment)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 153, in get_project
Aug 03 00:43:25 umbrel umbrel startup[22596]: verbose=verbose, version=api_version, context=context, environment=environment
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 43, in get_client
Aug 03 00:43:25 umbrel umbrel startup[22596]: environment=environment, tls_version=get_tls_version(environment)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
Aug 03 00:43:25 umbrel umbrel startup[22596]: client = APIClient(use_ssh_client=not use_paramiko_ssh, **kwargs)
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 197, in init
Aug 03 00:43:25 umbrel umbrel startup[22596]: self._version = self._retrieve_server_version()
Aug 03 00:43:25 umbrel umbrel startup[22596]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 222, in _retrieve_server_version
Aug 03 00:43:25 umbrel umbrel startup[22596]: ‘Error while fetching server API version: {0}’.format(e)
Aug 03 00:43:25 umbrel umbrel startup[22596]: docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionResetError(104, ‘Connection reset by peer’))
Aug 03 00:43:25 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Aug 03 00:43:25 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Aug 03 00:43:25 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Docker containers
Bitcoin Core logs
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.7/http/client.py”, line 1260, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1306, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1255, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1030, in _send_output
self.send(msg)
File “/usr/lib/python3.7/http/client.py”, line 970, in send
self.connect()
File “/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py”, line 43, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 533, in request
requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
LND logs
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Tor logs
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
==== Result ====
Please share the following links and paste it in the Umbrel Telegram group (https://t.me/getumbrel) so we can help you with your problem.
chunked=chunked)
self.send(msg)
self.connect()
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3/dist-packages/six.py”, line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
sys.exit(main())
command_func()
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command_func()
https://umbrel-paste.vercel.app/
umbrel@umbrel:~ $
