Unable to Start - Error: System service failed
Edit: If anyone stumbles upon this post,
Here are detailed steps on help with resolving the error: Resolving “Error: System service failed”
Feel free to ping me or reply in thread- or reach out via any of Umbrel’s official support avenues if any issue persists: https://www.umbrel.com/support
Hi, I’m getting the Error: System service failed message when starting my Umbrel, which started happening a couple months ago. Tried some of the basics from other support articles, but help appreciated if anyone can review the logs.
0.5.1
Flashed OS version
v0.3.2
Raspberry Pi Model
Revision : c03111
Serial : 100000005fc66c8e
Firmware
Jan 7 2021 18:27:29
Copyright (c) 2012 Broadcom
version fb345a0c2d5544957f4ba1a2b9e968970e3312c4 (clean) (release) (start)
Temperature
temp=38.4’C
Throttling
throttled=0x0
Mem: 3.8G 109M 3.4G 8.0M 312M 3.6G
Swap: 4.1G 0B 4.1G
total: 2.9%
system: 2.9%
tor: 0%
thunderhub: 0%
tailscale: 0%
sphinx-relay: 0%
pi-hole: 0%
oak-node: 0%
mempool: 0%
ln-visualizer: 0%
lnd: 0%
lnbits: 0%
lightning-terminal: 0%
lightning: 0%
electrs: 0%
electrs: 0%
core-lightning: 0%
bluewallet: 0%
bitfeed: 0%
bitcoin: 0%
bitcoin: 0%
Memory monitor logs
2022-10-20 19:28:56 Memory monitor running!
2022-10-20 19:29:14 Memory monitor running!
2022-10-20 19:29:27 Memory monitor running!
2022-10-20 19:29:40 Memory monitor running!
2022-10-20 19:29:54 Memory monitor running!
2022-10-20 19:30:08 Memory monitor running!
2022-10-20 19:30:25 Memory monitor running!
2022-10-20 19:30:38 Memory monitor running!
2022-10-20 19:30:52 Memory monitor running!
2022-10-20 19
/dev/root 29G 11G 18G 39% /
/dev/sda1 916G 916G 0 100% /home/umbrel/umbrel
Startup service logs
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 646, in send
Nov 20 12:39:17 umbrel umbrel startup[5251]: r = adapter.send(request, **kwargs)
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 498, in send
Nov 20 12:39:17 umbrel umbrel startup[5251]: raise ConnectionError(err, request=request)
Nov 20 12:39:17 umbrel umbrel startup[5251]: requests.exceptions.ConnectionError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Nov 20 12:39:17 umbrel umbrel startup[5251]: During handling of the above exception, another exception occurred:
Nov 20 12:39:17 umbrel umbrel startup[5251]: Traceback (most recent call last):
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/bin/docker-compose”, line 10, in
Nov 20 12:39:17 umbrel umbrel startup[5251]: sys.exit(main())
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 67, in main
Nov 20 12:39:17 umbrel umbrel startup[5251]: command()
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/main.py”, line 123, in perform_command
Nov 20 12:39:17 umbrel umbrel startup[5251]: project = project_from_options(‘.’, options)
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 69, in project_from_options
Nov 20 12:39:17 umbrel umbrel startup[5251]: environment_file=environment_file
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/command.py”, line 132, in get_project
Nov 20 12:39:17 umbrel umbrel startup[5251]: verbose=verbose, version=api_version, context=context, environment=environment
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 43, in get_client
Nov 20 12:39:17 umbrel umbrel startup[5251]: environment=environment, tls_version=get_tls_version(environment)
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/compose/cli/docker_client.py”, line 170, in docker_client
Nov 20 12:39:17 umbrel umbrel startup[5251]: client = APIClient(**kwargs)
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 197, in init
Nov 20 12:39:17 umbrel umbrel startup[5251]: self._version = self._retrieve_server_version()
Nov 20 12:39:17 umbrel umbrel startup[5251]: File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 222, in _retrieve_server_version
Nov 20 12:39:17 umbrel umbrel startup[5251]: ‘Error while fetching server API version: {0}’.format(e)
Nov 20 12:39:17 umbrel umbrel startup[5251]: docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
Nov 20 12:39:17 umbrel umbrel startup[5251]: Failed to start containers
Nov 20 12:39:17 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Nov 20 12:39:17 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Nov 20 12:39:17 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Sun 2022-11-20 11:48:06 UTC, end at Sun 2022-11-20 12:39:17 UTC. –
Nov 20 12:08:09 umbrel systemd[1]: Starting External Storage Mounter…
Nov 20 12:08:09 umbrel external storage mounter[498]: Running external storage mount script…
Nov 20 12:08:09 umbrel external storage mounter[498]: Found device "SABRENT "
Nov 20 12:08:09 umbrel external storage mounter[498]: Blacklisting USB device IDs against UAS driver…
Nov 20 12:08:09 umbrel external storage mounter[498]: Rebinding USB drivers…
Nov 20 12:08:09 umbrel external storage mounter[498]: Checking USB devices are back…
Nov 20 12:08:09 umbrel external storage mounter[498]: Waiting for USB devices…
Nov 20 12:08:10 umbrel external storage mounter[498]: Waiting for USB devices…
Nov 20 12:08:11 umbrel external storage mounter[498]: Checking if the device is ext4…
Nov 20 12:08:11 umbrel external storage mounter[498]: Yes, it is ext4
Nov 20 12:08:12 umbrel external storage mounter[498]: Checking if device contains an Umbrel install…
Nov 20 12:08:12 umbrel external storage mounter[498]: Yes, it contains an Umbrel install
Nov 20 12:08:12 umbrel external storage mounter[498]: Bind mounting external storage over local Umbrel installation…
Nov 20 12:08:12 umbrel external storage mounter[498]: Bind mounting external storage over local Docker data dir…
Nov 20 12:08:12 umbrel external storage mounter[498]: Bind mounting external storage to /swap
Nov 20 12:08:12 umbrel external storage mounter[498]: Bind mounting SD card root at /sd-card…
Nov 20 12:08:12 umbrel external storage mounter[498]: Checking Umbrel root is now on external storage…
Nov 20 12:08:13 umbrel external storage mounter[498]: Checking /var/lib/docker is now on external storage…
Nov 20 12:08:13 umbrel external storage mounter[498]: Checking /swap is now on external storage…
Nov 20 12:08:13 umbrel external storage mounter[498]: Setting up swapfile
Nov 20 12:08:13 umbrel external storage mounter[498]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 20 12:08:13 umbrel external storage mounter[498]: no label, UUID=f802011a-e6b8-4870-bf2c-ffc2b7cd134b
Nov 20 12:08:13 umbrel external storage mounter[498]: Checking SD Card root is bind mounted at /sd-root…
Nov 20 12:08:13 umbrel external storage mounter[498]: Starting external drive mount monitor…
Nov 20 12:08:13 umbrel external storage mounter[498]: Mount script completed successfully!
Nov 20 12:08:13 umbrel systemd[1]: Started External Storage Mounter.
Nov 20 12:08:22 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 20 12:08:22 umbrel external storage updater[856]: Checking if SD card Umbrel is newer than external storage…
Nov 20 12:08:22 umbrel external storage updater[856]: No, SD version is not newer, exiting.
Nov 20 12:08:22 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/26994’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/6560’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/22562’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/16307’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/26464’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/16226’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/26197’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/13789’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
mkdir: cannot create directory ‘/home/umbrel/umbrel/.backup/8506’: No space left on device
Got signal: backup
Deriving keys…
Creating backup…
Docker containers
Umbrel logs
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.7/http/client.py”, line 1260, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1306, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1255, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.7/http/client.py”, line 1030, in _send_output
self.send(msg)
File “/usr/lib/python3.7/http/client.py”, line 970, in send
self.connect()
File “/usr/local/lib/python3.7/dist-packages/docker/transport/unixconn.py”, line 43, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/lib/python3/dist-packages/six.py”, line 692, in reraise
raise value.with_traceback(tb)
chunked=chunked)
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: (‘Connection aborted.’, ConnectionRefusedError(111, ‘Connection refused’))
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 214, in _retrieve_server_version
return self.version(api_version=False)[“ApiVersion”]
File “/usr/local/lib/python3.7/dist-packages/docker/api/daemon.py”, line 181, in version
return self._result(self._get(url), json=True)
File “/usr/local/lib/python3.7/dist-packages/docker/utils/decorators.py”, line 46, in inner
return f(self, *args, **kwargs)
File “/usr/local/lib/python3.7/dist-packages/docker/api/client.py”, line 237, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
sys.exit(main())
command()
Tor logs
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command()
App logs
bitcoin
chunked=chunked)
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked)
self.send(msg)
self.connect()
sys.exit(main())
command()
“tailscale”,
[Had to skip a bunch of the same due to length - all apps give the same errors]
==== Result ====
Unfortunately, so am I. Getting this same kind of error messages in my logs. Re-flashed my microSD card; still the same problem - can’t get dashboard to come up!
I found that I had to run this command (from the official Troubleshooting guide):
rm -f ~/umbrel/statuses/update-in-progress && sudo reboot
I also had to clear my browser cache to be able to get the Umbrel dashboard to come back up. Right now it seems I’m waiting on electrs service to start.
UPDATE: And now the dashboard does display that it is “Deleting previous images”, and log files show that electrs did finally start. My experience with my Raspberry Pi 4 with an 8GB RAM is that this restart process can take 10-15min. just to get back up and running and to start to clean up the previously failed update process.
UPDATE 2: … 30min. later - finally got back into my Umbrel node via the browser dashboard interface. Hopefully this real-time edits of my post explaining the reality of “fixing” your Umbrel node is helpful to others!
Thanks for the reply! No luck for those unfortunately - thinking about going for wiping and restoring channels - no other option at this stage.
To be fair, I tried the command in my Nov. 30 note once, and it didn’t seem to take, or maybe I just didn’t wait long enough for my Umbrel to reboot. So you may want to try it again.
