After adding many nodes i manage to have around 15-18 peers ( clearnet & tor ). However the node does not download the missing blocks and therefore does not sync.
The bitcoind logs show some recurring elements that tickles me but i might not understand fully.
The first one is this :
2023-02-09T14:19:52Z Potential stale tip detected, will try using extra outbound peer (last tip update: 3778 seconds ago)
The second one is this :
2023-02-09T13:58:36Z Timeout downloading headers from peer=61, disconnecting
I don’t get why this happens nor what i can do to resync the node. I must admit i’m a bit stressed out as i have 7 channels opened on LN that i can not manage nor monitor until the node get resynced.
Any help would be really appreciated <3
P.S : I ran the following command, no inconsistency found :
Yes, the node had access to the internet. Everything looked to run fine.
I ended reindexing the chainstate, which seems to have fixed the problem. It took a few days due to latency of the connection but after reindexing the local bitcoind managed to catch up with remote peers.
I still have no explanation on what happened.
I uninstalled many applications to see if any could be source of the problem, nothing was changing.
Digging on the web i found this: https://bitcoin.stackexchange.com/a/115298 . However i found it after starting the reindex and didn’t think on trying to uninstall mempool first, so i can’t ensure this could be linked.
I was having a similar issue, since October 2023, and I reflashed my SD (on the current and a new one) and am able to get into the Umbrel home, but now I cannot connect to any app - Bitcoin never updates/loads/refreshes, stuck in “Starting”, and Mempool says OFFLINE with flashes of RECONNECTING… so seems like it’s not online.
I followed the SSH instructions and logged into my node that way, and tried pinging 8.8.8.8 - didn’t seem to work… just kept pinging for a long time (vs. when I do it from my local computer, it worked after 4 pings no problem).
How do I troubleshoot getting my node back on the internet? It’s clearly connected to my router because I can SSH in through my wifi.
Troubleshooting log is attached (from after my Umbrel OS update to 0.5.4
