I have been running umbrell for last few months. I did some upgrades. Got some issues which i fixed base on well prepared documentation. I have unusual issue.
I am not able execute any command.
Yesterday I noticed that umbrel node didn’t work. I couldn’t connect via ssh so I disconnected it from power. Now I can start node I can connect via ssh however webgui still doesn’t work. The main problem is that even if I connect I am not able to execute many commands. Fof instance for:
sudo ./scripts/debug --upload
0.4.4
Flashed OS version
v0.3.2
Raspberry Pi Model
Revision : c03112
Serial : 10000000eef0e9d1
Model : Raspberry Pi 4 Model B Rev 1.2Firmware
Jan 7 2021 18:27:29
Copyright (c) 2012 Broadcom
version fb345a0c2d5544957f4ba1a2b9e968970e3312c4 (clean) (release) (start)Temperature
temp=45.7’C
Throttling
throttled=0x0
total used free shared buff/cache availableMem: 3.8G 174M 3.3G 8.0M 286M 3.5G
Swap: 4.1G 0B 4.1G
In the past I also installed a few useful progs like htop, mc and others. None of them doesn’t work.
The same problem is for commands like:
docker ps -a
for
sudo ./scripts/stop
i got
Stopping installed apps…
Stopping app bluewallet…
Stopping app lightning-terminal…
Stopping app thunderhub…
Stopping app btc-rpc-explorer…
Stopping app sphinx-relay…
Stopping app specter-desktop…
Stopping app mempool…
and that’s it. I cannot get prompt. I cannot get any logs.
Normally I would reflash SD card however I cannot do it. I have a few milions satoshi there so I would like to get it back.
I have just got a msg error like this:
/home/umbrel/umbrel/scripts/…/scripts/app: line 103: 14398 Segmentation fault docker-compose --env-file “${env_file}” --project-name “${app}” --file “${app_base_compose_file}” --fil
e “${app_compose_file}” “${@}”
Could you please help me to fix this issue?
