No bitcoin peers
I don’t show any bitcoin peers. I tried searching for peers.dat to delete, but I can’t seem to find the path.
Also, when I open Umbrel and go to Settings > System > Troubleshoot, I receive the error message, “”.
I’m on version 0.5.3.
Umbrel logs
0.5.3
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision	: c03112
Serial		: 10000000887fbc5e
Model		: Raspberry Pi 4 Model B Rev 1.2
Firmware
Oct 29 2021 10:47:33
Copyright (c) 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=58.4'C
Throttling
throttled=0x50005
Mem:           3.8G        1.4G        1.3G         10M        1.1G        2.3G
Swap:          4.1G          0B        4.1G
total: 36.5%
lightning: 15.9%
electrs: 14.6%
bitcoin: 9.1%
mempool: 8.5%
thunderhub: 8.3%
system: 0%
Memory monitor logs
2022-04-19 21:23:40 Warning memory usage at 91%
2022-12-06 22:16:52 Memory monitor running!
 3724 ?        S      0:01 bash ./scripts/memory-monitor
 3724 ?        S      0:02 bash ./scripts/memory-monitor
2022-12-07 23:11:39 Memory monitor running!
2022-12-13 17:33:43 Memory monitor running!
2022-12-13 17:48:36 Memory monitor running!
2022-12-13 21:52:37 Memory monitor running!
/dev/root        15G  3.3G   11G  25% /
/dev/sda1       916G  530G  340G  61% /home/umbrel/umbrel
Startup service logs
Dec 13 21:53:31 umbrel umbrel startup[982]: Creating electrs_app_1        ...
Dec 13 21:53:34 umbrel umbrel startup[982]: Creating thunderhub_tor_server_1 ... done
Dec 13 21:53:34 umbrel umbrel startup[982]: Creating electrs_tor_server_1 ... done
Dec 13 21:53:35 umbrel umbrel startup[982]: Creating thunderhub_web_1        ... done
Dec 13 21:53:36 umbrel umbrel startup[982]: Creating thunderhub_app_proxy_1  ... done
Dec 13 21:53:36 umbrel umbrel startup[982]: Creating electrs_app_proxy_1  ... done
Dec 13 21:53:36 umbrel umbrel startup[982]: Creating electrs_tor_1        ... done
Dec 13 21:53:39 umbrel umbrel startup[982]: Creating lightning_app_proxy_1  ... done
Dec 13 21:53:41 umbrel umbrel startup[982]: Creating bitcoin_tor_server_1 ... done
Dec 13 21:53:41 umbrel umbrel startup[982]: Creating lightning_tor_server_1 ... done
Dec 13 21:53:42 umbrel umbrel startup[982]: Creating lightning_app_1        ... done
Dec 13 21:53:42 umbrel umbrel startup[982]: Creating mempool_tor_server_1 ... done
Dec 13 21:53:43 umbrel umbrel startup[982]: Creating lightning_tor_1        ... done
Dec 13 21:53:43 umbrel umbrel startup[982]: Creating bitcoin_app_proxy_1  ... done
Dec 13 21:53:44 umbrel umbrel startup[982]: Creating mempool_mariadb_1    ... done
Dec 13 21:53:44 umbrel umbrel startup[982]: Creating mempool_api_1        ... done
Dec 13 21:53:44 umbrel umbrel startup[982]: Creating bitcoin_tor_1        ... done
Dec 13 21:53:44 umbrel umbrel startup[982]: Creating mempool_web_1        ... done
Dec 13 21:53:45 umbrel umbrel startup[982]: Creating mempool_app_proxy_1  ... done
Dec 13 21:53:46 umbrel umbrel startup[982]: Creating electrs_app_1        ... done
Dec 13 21:53:46 umbrel umbrel startup[982]: Creating bitcoin_bitcoind_1   ... done
Dec 13 21:53:46 umbrel umbrel startup[982]: Creating bitcoin_server_1     ...
Dec 13 21:53:47 umbrel umbrel startup[982]: Creating lightning_lnd_1        ... done
Dec 13 21:53:50 umbrel umbrel startup[982]: Creating bitcoin_server_1     ... done
Dec 13 21:53:51 umbrel umbrel startup[982]: Umbrel is now accessible at
Dec 13 21:53:51 umbrel umbrel startup[982]:   http://umbrel.local
Dec 13 21:53:51 umbrel umbrel startup[982]:   http://192.168.1.226
Dec 13 21:53:51 umbrel systemd[1]: Started Umbrel Startup Service.
Dec 13 21:53:56 umbrel passwd[6807]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
Dec 13 21:52:23 umbrel systemd[1]: Starting External Storage Mounter...
Dec 13 21:52:23 umbrel external storage mounter[498]: Running external storage mount script...
Dec 13 21:52:24 umbrel external storage mounter[498]: Found device "SanDisk Extreme 55AE"
Dec 13 21:52:24 umbrel external storage mounter[498]: Blacklisting USB device IDs against UAS driver...
Dec 13 21:52:24 umbrel external storage mounter[498]: Rebinding USB drivers...
Dec 13 21:52:24 umbrel external storage mounter[498]: Checking USB devices are back...
Dec 13 21:52:24 umbrel external storage mounter[498]: Waiting for USB devices...
Dec 13 21:52:25 umbrel external storage mounter[498]: Waiting for USB devices...
Dec 13 21:52:26 umbrel external storage mounter[498]: Checking if the device is ext4...
Dec 13 21:52:26 umbrel external storage mounter[498]: Yes, it is ext4
Dec 13 21:52:26 umbrel external storage mounter[498]: Checking filesystem for corruption...
Dec 13 21:52:26 umbrel external storage mounter[498]: e2fsck 1.44.5 (15-Dec-2018)
Dec 13 21:52:27 umbrel external storage mounter[498]: umbrel: clean, 316413/61046784 files, 142889861/244182016 blocks
Dec 13 21:52:27 umbrel external storage mounter[498]: Mounting partition...
Dec 13 21:52:27 umbrel external storage mounter[498]: Checking if device contains an Umbrel install...
Dec 13 21:52:28 umbrel external storage mounter[498]: Yes, it contains an Umbrel install
Dec 13 21:52:28 umbrel external storage mounter[498]: Bind mounting external storage over local Umbrel installation...
Dec 13 21:52:28 umbrel external storage mounter[498]: Bind mounting external storage over local Docker data dir...
Dec 13 21:52:28 umbrel external storage mounter[498]: Bind mounting external storage to /swap
Dec 13 21:52:28 umbrel external storage mounter[498]: Bind mounting SD card root at /sd-card...
Dec 13 21:52:28 umbrel external storage mounter[498]: Checking Umbrel root is now on external storage...
Dec 13 21:52:29 umbrel external storage mounter[498]: Checking /var/lib/docker is now on external storage...
Dec 13 21:52:29 umbrel external storage mounter[498]: Checking /swap is now on external storage...
Dec 13 21:52:29 umbrel external storage mounter[498]: Setting up swapfile
Dec 13 21:52:29 umbrel external storage mounter[498]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 13 21:52:29 umbrel external storage mounter[498]: no label, UUID=db46f6fd-b165-4034-bafc-ee7145a1603c
Dec 13 21:52:29 umbrel external storage mounter[498]: Checking SD Card root is bind mounted at /sd-root...
Dec 13 21:52:29 umbrel external storage mounter[498]: Starting external drive mount monitor...
Dec 13 21:52:29 umbrel external storage mounter[498]: Mount script completed successfully!
Dec 13 21:52:29 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Tue 2022-12-13 21:52:19 UTC, end at Tue 2022-12-13 21:54:46 UTC. --
Dec 13 21:52:37 umbrel systemd[1]: Starting External Storage SDcard Updater...
Dec 13 21:52:37 umbrel external storage updater[905]: Checking if SD card Umbrel is newer than external storage...
Dec 13 21:52:37 umbrel external storage updater[905]: No, SD version is not newer, exiting.
Dec 13 21:52:37 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
=============== UPDATE ================
=========== Stage: Success ============
Removing backup
Successfully installed Umbrel v0.5.3
== End Update Script 03-run.sh ==
Deleting cloned repository
Removing lock
Got signal: change-password
karen is getting triggered!
Got signal: backup
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
9502 bytes (9.5 kB, 9.3 KiB) copied, 0.000378846 s, 25.1 MB/s
Creating encrypted tarball...
backup/
backup/.padding
backup/channel.backup
Uploading backup...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                             Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (7) Can't complete SOCKS5 connection to 0.0.0.0:0. (1)
====== Backup failed =======
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES                     STATUS
bitcoin_server_1          Up About a minute
electrs_app_1             Up About a minute
mempool_mariadb_1         Up About a minute
mempool_app_proxy_1       Up About a minute
mempool_api_1             Up About a minute
mempool_tor_server_1      Up About a minute
mempool_web_1             Up About a minute
bitcoin_bitcoind_1        Up About a minute
bitcoin_app_proxy_1       Up About a minute
bitcoin_tor_server_1      Up About a minute
bitcoin_tor_1             Up About a minute
lightning_tor_server_1    Up About a minute
lightning_lnd_1           Up About a minute
lightning_app_1           Up About a minute
lightning_tor_1           Up About a minute
lightning_app_proxy_1     Up About a minute
thunderhub_web_1          Up About a minute
thunderhub_app_proxy_1    Up About a minute
thunderhub_tor_server_1   Up About a minute
electrs_app_proxy_1       Up About a minute
electrs_tor_1             Up About a minute
electrs_tor_server_1      Up About a minute
electrs_electrs_1         Up About a minute
nginx                     Up 2 minutes
tor_server                Up 2 minutes
tor_proxy                 Up 2 minutes
manager                   Up 2 minutes
dashboard                 Up 2 minutes
auth                      Up 2 minutes
Umbrel logs
Attaching to manager
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:44 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | umbrel-manager
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:46 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:47 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:49 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:50 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:52 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:53 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:54 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:56 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.21.2 - - [Tue, 13 Dec 2022 21:54:57 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy    | Dec 13 21:52:47.865 [notice] You configured a non-loopback address '10.21.21.11:9050' for SocksPort. This allows everybody on your local network to use your machine as a proxy. Make sure this is what you wanted.
tor_proxy    | Dec 13 21:52:47.866 [warn] You have a ControlPort set to accept connections from a non-local address.  This means that programs not running on your computer can reconfigure your Tor.  That's pretty bad, since the controller protocol isn't encrypted!  Maybe you should just listen on 127.0.0.1 and use a tool like stunnel or ssh to encrypt remote connections to your control port.
tor_proxy    | Dec 13 21:52:47.871 [notice] Opening Socks listener on 10.21.21.11:9050
tor_proxy    | Dec 13 21:52:47.871 [notice] Opened Socks listener connection (ready) on 10.21.21.11:9050
tor_proxy    | Dec 13 21:52:47.871 [notice] Opening Control listener on 10.21.21.11:29051
tor_proxy    | Dec 13 21:52:47.871 [notice] Opened Control listener connection (ready) on 10.21.21.11:29051
tor_proxy    | Dec 13 21:52:47.000 [notice] Bootstrapped 0% (starting): Starting
tor_proxy    | Dec 13 21:52:47.000 [notice] Starting with guard context "default"
tor_proxy    | Dec 13 21:52:48.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor_proxy    | Dec 13 21:52:52.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_app_proxy_1, bitcoin_tor_server_1, bitcoin_tor_1
server_1      | yarn run v1.22.18
server_1      | $ node ./bin/www
server_1      | Tue, 13 Dec 2022 21:54:10 GMT morgan deprecated morgan(options): use morgan("default", options) instead at app.js:33:9
server_1      | Tue, 13 Dec 2022 21:54:10 GMT morgan deprecated default format: use combined format at app.js:33:9
server_1      | Listening on port 3005
app_proxy_1   | yarn run v1.22.19
app_proxy_1   | $ node ./bin/www
app_proxy_1   | [HPM] Proxy created: /  -> http://10.21.22.2:3005
app_proxy_1   | Waiting for 10.21.22.2:3005 to open...
app_proxy_1   | Bitcoin Node is now ready...
app_proxy_1   | Listening on port: 2100
bitcoind_1    | 2022-12-13T21:54:05Z init message: Loading block index…
bitcoind_1    | 2022-12-13T21:54:05Z Assuming ancestors of block 00000000000000000009c97098b5295f7e5f183ac811fb5d1534040adb93cabd have valid signatures.
bitcoind_1    | 2022-12-13T21:54:05Z Setting nMinimumChainWork=00000000000000000000000000000000000000003404ba0801921119f903495e
bitcoind_1    | 2022-12-13T21:54:05Z Switching active chainstate to Chainstate [ibd] @ height -1 (null)
bitcoind_1    | 2022-12-13T21:54:05Z Opening LevelDB in /data/.bitcoin/blocks/index
bitcoind_1    | 2022-12-13T21:54:05Z Opened LevelDB successfully
bitcoind_1    | 2022-12-13T21:54:05Z Using obfuscation key for /data/.bitcoin/blocks/index: 0000000000000000
bitcoind_1    | 2022-12-13T21:55:00Z LoadBlockIndexDB: last block file = 3005
bitcoind_1    | 2022-12-13T21:55:00Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=45, size=53374364, heights=732603...732647, time=2022-04-19...2022-04-20)
bitcoind_1    | 2022-12-13T21:55:00Z Checking all blk files are present...
tor_1         | Dec 13 21:53:44.556 [notice] Tor 0.4.7.8 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
tor_1         | Dec 13 21:53:44.556 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://support.torproject.org/faq/staying-anonymous/
tor_1         | Dec 13 21:53:44.557 [notice] Read configuration file "/etc/tor/torrc".
tor_1         | Dec 13 21:53:44.660 [notice] Opening Socks listener on 127.0.0.1:9050
tor_1         | Dec 13 21:53:44.660 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_1         | Dec 13 21:53:45.000 [notice] Bootstrapped 0% (starting): Starting
tor_1         | Dec 13 21:53:45.000 [notice] Starting with guard context "default"
tor_1         | Dec 13 21:53:46.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
electrs
Attaching to electrs_app_1, electrs_app_proxy_1, electrs_tor_1, electrs_tor_server_1, electrs_electrs_1
app_1         | > umbrel-electrs@1.0.1 dev:backend
app_1         | > npm run start -w umbrel-electrs-backend
app_1         |
app_1         |
app_1         | > umbrel-electrs-backend@0.1.12 start
app_1         | > node ./bin/www
app_1         |
app_1         | Tue, 13 Dec 2022 21:54:28 GMT morgan deprecated morgan(options): use morgan("default", options) instead at app.js:28:9
app_1         | Tue, 13 Dec 2022 21:54:28 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1         | Listening on port 3006
app_proxy_1   | [HPM] Proxy created: /  -> http://10.21.22.4:3006
app_proxy_1   | Waiting for 10.21.22.4:3006 to open...
app_proxy_1   | Electrs is now ready...
app_proxy_1   | Listening on port: 2102
electrs_1     | [2022-12-13T21:55:03.765Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:04.773Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:05.781Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:06.795Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:07.801Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:08.806Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:09.810Z INFO  electrs::daemon] waiting for RPC warmup: Loading block index…
electrs_1     | [2022-12-13T21:55:10.817Z INFO  electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1     | [2022-12-13T21:55:11.823Z INFO  electrs::daemon] waiting for RPC warmup: Verifying blocks…
electrs_1     | [2022-12-13T21:55:12.828Z INFO  electrs::daemon] waiting for RPC warmup: Verifying blocks…
tor_1         | Dec 13 21:53:36.566 [notice] Tor 0.4.7.8 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
tor_1         | Dec 13 21:53:36.566 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://support.torproject.org/faq/staying-anonymous/
tor_1         | Dec 13 21:53:36.575 [notice] Read configuration file "/etc/tor/torrc".
tor_1         | Dec 13 21:53:36.622 [notice] Opening Socks listener on 127.0.0.1:9050
tor_1         | Dec 13 21:53:36.623 [notice] Opened Socks listener connection (ready) on 127.0.0.1:9050
tor_1         | Dec 13 21:53:37.000 [notice] Bootstrapped 0% (starting): Starting
tor_1         | Dec 13 21:53:37.000 [notice] Starting with guard context "default"
tor_1         | Dec 13 21:53:38.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
lightning
Attaching to lightning_tor_server_1, lightning_lnd_1, lightning_app_1, lightning_tor_1, lightning_app_proxy_1
app_proxy_1   | [HPM] Proxy created: /  -> http://10.21.22.3:3006
app_proxy_1   | Waiting for 10.21.22.3:3006 to open...
app_proxy_1   | Lightning Node is now ready...
app_proxy_1   | Listening on port: 2101
app_1         | Checking LND status...
app_1         | Waiting for LND...
lnd_1         | 2022-12-13 21:53:49.260 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd_1         | 2022-12-13 21:53:49.410 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd_1         | 2022-12-13 21:53:49.581 [INF] LTND: Opening the main database, this might take a few minutes...
lnd_1         | 2022-12-13 21:53:49.591 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd_1         | 2022-12-13 21:54:36.066 [INF] LTND: Creating local graph and channel state DB instances
lnd_1         | 2022-12-13 21:54:44.600 [INF] CHDB: Checking for schema update: latest_version=29, db_version=29
lnd_1         | 2022-12-13 21:54:44.602 [INF] CHDB: Checking for optional update: prune_revocation_log=false, db_version=empty
lnd_1         | 2022-12-13 21:54:44.603 [INF] LTND: Database(s) now open (time_to_open=54.691393887s)!
lnd_1         | 2022-12-13 21:54:44.604 [INF] LTND: We're not running within systemd or the service type is not 'notify'
lnd_1         | 2022-12-13 21:54:44.604 [INF] LTND: Waiting for wallet encryption password. Use `lncli create` to create a wallet, `lncli unlock` to unlock an existing wallet, or `lncli changepassword` to change the password of an existing wallet and unlock it.
tor_1         | Dec 13 21:53:46.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor_1         | Dec 13 21:53:46.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor_1         | Dec 13 21:53:46.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor_1         | Dec 13 21:53:47.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor_1         | Dec 13 21:53:47.000 [notice] Bootstrapped 30% (loading_status): Loading networkstatus consensus
tor_1         | Dec 13 21:53:51.000 [notice] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
tor_1         | Dec 13 21:53:51.000 [notice] Bootstrapped 40% (loading_keys): Loading authority key certs
tor_1         | Dec 13 21:53:54.000 [notice] Bootstrapped 45% (requesting_descriptors): Asking for relay descriptors
tor_1         | Dec 13 21:53:54.000 [notice] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/6038, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of end bw (no exits in consensus, using mid) = 0% of path bw.)
mempool
Attaching to mempool_mariadb_1, mempool_app_proxy_1, mempool_api_1, mempool_tor_server_1, mempool_web_1
api_1         | Dec 13 21:54:15 [97] INFO: Database connection established.
api_1         | Dec 13 21:54:15 [97] INFO: Starting statistics service
api_1         | Dec 13 21:54:15 [97] INFO: Starting currency rates service
api_1         | Dec 13 21:54:15 [97] INFO: Currency rates service will be queried over clearnet using https://price.bisq.wiz.biz/getAllMarketPrices
api_1         | Dec 13 21:54:16 [97] NOTICE: Mempool Server is running on port 8999
api_1         | Dec 13 21:54:16 [97] INFO: Updating latest mining pools from Github
api_1         | Dec 13 21:54:16 [97] INFO: List of public pools will be queried over clearnet
api_1         | Dec 13 21:54:22 [97] WARN: runMainLoop error: Loading block index…. Retrying in 10 sec.
api_1         | Dec 13 21:54:33 [97] WARN: runMainLoop error: Loading block index…. Retrying in 20 sec.
api_1         | Dec 13 21:54:53 [97] WARN: runMainLoop error: Loading block index…. Retrying in 40 sec.
mariadb_1     | 2022-12-13 21:53:52 0 [Note] Plugin 'FEEDBACK' is disabled.
mariadb_1     | 2022-12-13 21:53:52 0 [Note] Server socket created on IP: '::'.
mariadb_1     | 2022-12-13 21:53:52 0 [Warning] 'proxies_priv' entry '@% root@b4082fa4f425' ignored in --skip-name-resolve mode.
mariadb_1     | 2022-12-13 21:53:53 0 [Note] Reading of all Master_info entries succeeded
mariadb_1     | 2022-12-13 21:53:53 0 [Note] Added new Master_info '' to hash table
mariadb_1     | 2022-12-13 21:53:53 0 [Note] mysqld: ready for connections.
mariadb_1     | Version: '10.5.12-MariaDB-1:10.5.12+maria~focal'  socket: '/run/mysqld/mysqld.sock'  port: 3306  mariadb.org binary distribution
mariadb_1     | 2022-12-13 21:53:53 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
mariadb_1     | 2022-12-13 21:53:53 4 [Warning] Aborted connection 4 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.27' (This connection closed normally without authentication)
mariadb_1     | 2022-12-13 21:53:54 0 [Note] InnoDB: Buffer pool(s) load completed at 221213 21:53:54
app_proxy_1   | [HPM] Proxy created: /  -> http://10.21.21.26:3006
app_proxy_1   | Waiting for 10.21.21.26:3006 to open...
app_proxy_1   | mempool is now ready...
app_proxy_1   | Listening on port: 3006
thunderhub
Attaching to thunderhub_web_1, thunderhub_app_proxy_1, thunderhub_tor_server_1
app_proxy_1   | [HPM] Proxy created: /  -> http://thunderhub_web_1:3000
app_proxy_1   | Waiting for thunderhub_web_1:3000 to open...
app_proxy_1   | ThunderHub is now ready...
app_proxy_1   | Listening on port: 3000
web_1         | {
web_1         |   message: 'UnableToConnectToAnyNode',
web_1         |   level: 'error',
web_1         |   timestamp: '2022-12-13T21:55:22.039Z'
web_1         | }
web_1         | {
web_1         |   message: 'Initiating subscriptions failed: ',
web_1         |   timestamp: '2022-12-13T21:55:22.042Z'
web_1         | }
==== Result ====
There is probably issue with your power supply. We recommend using the official power supply to avoid this issue
The command to delete and the path for peers.dat is:
rm /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/peers.dat
You should first stop Bitcoin with:
~/umbrel/scripts/app stop bitcoin
Then you can start it again, I have the steps here: http://community.umbrel.com/t/umbrel-is-running-and-dashboard-is-ok-but-node-is-blank/10072/12?u=usernameisjim
It may also help to flash to the latest version, you can download the latest Umbrel version here: https://download.umbrel.com/umbrel-os.zip
Let me know if that works!
I tried deleting peers.dat, but I still don’t have any peers after 20 minutes. My log files are below. What should I try next? I’ve also tried rebooting several times.
Umbrel logs
0.5.3
Flashed OS version
v0.4.8
Raspberry Pi Model
Revision	: c03112
Firmware
Temperature
temp=51.6'C
Throttling
throttled=0x50000
Mem:           3.8G        1.8G        410M        4.0M        1.6G        1.9G
Swap:          4.1G        7.0M        4.1G
total: 47.6%
bitcoin: 17.9%
lightning: 17.6%
electrs: 11.5%
thunderhub: 9.3%
mempool: 8.5%
system: 0%
Memory monitor logs
2022-12-14 17:37:44 Memory monitor running!
Dec 14 17:38:39 umbrel umbrel startup[993]: Creating thunderhub_tor_server_1 ... done
Dec 14 17:38:40 umbrel umbrel startup[993]: Creating electrs_tor_server_1 ... done
Dec 14 17:38:40 umbrel umbrel startup[993]: Creating electrs_tor_1        ... done
Dec 14 17:38:40 umbrel umbrel startup[993]: Creating thunderhub_web_1        ... done
Dec 14 17:38:41 umbrel umbrel startup[993]: Creating thunderhub_app_proxy_1  ... done
Dec 14 17:38:42 umbrel umbrel startup[993]: Creating electrs_electrs_1    ... done
Dec 14 17:38:43 umbrel umbrel startup[993]: Creating electrs_app_1        ...
Dec 14 17:38:44 umbrel umbrel startup[993]: Creating bitcoin_tor_server_1 ... done
Dec 14 17:38:45 umbrel umbrel startup[993]: Creating electrs_app_proxy_1  ... done
Dec 14 17:38:49 umbrel umbrel startup[993]: Creating mempool_web_1        ... done
Dec 14 17:38:49 umbrel umbrel startup[993]: Creating lightning_app_1        ... done
Dec 14 17:38:50 umbrel umbrel startup[993]: Creating lightning_tor_1        ... done
Dec 14 17:38:50 umbrel umbrel startup[993]: Creating bitcoin_app_proxy_1  ... done
Dec 14 17:38:51 umbrel umbrel startup[993]: Creating lightning_tor_server_1 ... done
Dec 14 17:38:52 umbrel umbrel startup[993]: Creating bitcoin_tor_1        ... done
Dec 14 17:38:52 umbrel umbrel startup[993]: Creating lightning_app_proxy_1  ... done
Dec 14 17:38:52 umbrel umbrel startup[993]: Creating bitcoin_bitcoind_1   ... done
Dec 14 17:38:53 umbrel umbrel startup[993]: Creating mempool_tor_server_1 ... done
Dec 14 17:38:53 umbrel umbrel startup[993]: Creating bitcoin_server_1     ...
Dec 14 17:38:53 umbrel umbrel startup[993]: Creating mempool_mariadb_1    ... done
Dec 14 17:38:53 umbrel umbrel startup[993]: Creating mempool_api_1        ... done
Dec 14 17:38:54 umbrel umbrel startup[993]: Creating mempool_app_proxy_1  ... done
Dec 14 17:38:55 umbrel umbrel startup[993]: Creating electrs_app_1        ... done
Dec 14 17:38:55 umbrel umbrel startup[993]: Creating lightning_lnd_1        ... done
Dec 14 17:38:58 umbrel umbrel startup[993]: Creating bitcoin_server_1     ... done
Dec 14 17:38:59 umbrel umbrel startup[993]: Umbrel is now accessible at
Dec 14 17:38:59 umbrel umbrel startup[993]:   http://umbrel.local
Dec 14 17:38:59 umbrel umbrel startup[993]:   http://192.168.1.226
Dec 14 17:38:59 umbrel systemd[1]: Started Umbrel Startup Service.
Dec 14 17:37:30 umbrel systemd[1]: Starting External Storage Mounter...
Dec 14 17:37:30 umbrel external storage mounter[497]: Running external storage mount script...
Dec 14 17:37:30 umbrel external storage mounter[497]: Found device "SanDisk Extreme 55AE"
Dec 14 17:37:30 umbrel external storage mounter[497]: Blacklisting USB device IDs against UAS driver...
Dec 14 17:37:30 umbrel external storage mounter[497]: Rebinding USB drivers...
Dec 14 17:37:30 umbrel external storage mounter[497]: Checking USB devices are back...
Dec 14 17:37:30 umbrel external storage mounter[497]: Waiting for USB devices...
Dec 14 17:37:31 umbrel external storage mounter[497]: Waiting for USB devices...
Dec 14 17:37:32 umbrel external storage mounter[497]: Checking if the device is ext4...
Dec 14 17:37:32 umbrel external storage mounter[497]: Yes, it is ext4
Dec 14 17:37:32 umbrel external storage mounter[497]: Checking filesystem for corruption...
Dec 14 17:37:32 umbrel external storage mounter[497]: e2fsck 1.44.5 (15-Dec-2018)
Dec 14 17:37:34 umbrel external storage mounter[497]: umbrel: clean, 316403/61046784 files, 142889778/244182016 blocks
Dec 14 17:37:34 umbrel external storage mounter[497]: Mounting partition...
Dec 14 17:37:34 umbrel external storage mounter[497]: Checking if device contains an Umbrel install...
Dec 14 17:37:34 umbrel external storage mounter[497]: Yes, it contains an Umbrel install
Dec 14 17:37:34 umbrel external storage mounter[497]: Bind mounting external storage over local Umbrel installation...
Dec 14 17:37:34 umbrel external storage mounter[497]: Bind mounting external storage over local Docker data dir...
Dec 14 17:37:34 umbrel external storage mounter[497]: Bind mounting external storage to /swap
Dec 14 17:37:34 umbrel external storage mounter[497]: Bind mounting SD card root at /sd-card...
Dec 14 17:37:34 umbrel external storage mounter[497]: Checking Umbrel root is now on external storage...
Dec 14 17:37:35 umbrel external storage mounter[497]: Checking /var/lib/docker is now on external storage...
Dec 14 17:37:35 umbrel external storage mounter[497]: Checking /swap is now on external storage...
Dec 14 17:37:35 umbrel external storage mounter[497]: Setting up swapfile
Dec 14 17:37:36 umbrel external storage mounter[497]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 14 17:37:36 umbrel external storage mounter[497]: no label, UUID=26c5bdfa-cd65-45d3-8f22-bd588e267c12
Dec 14 17:37:36 umbrel external storage mounter[497]: Checking SD Card root is bind mounted at /sd-root...
Dec 14 17:37:36 umbrel external storage mounter[497]: Starting external drive mount monitor...
Dec 14 17:37:36 umbrel external storage mounter[497]: Mount script completed successfully!
Dec 14 17:37:36 umbrel systemd[1]: Started External Storage Mounter.
-- Logs begin at Wed 2022-12-14 17:37:25 UTC, end at Wed 2022-12-14 18:04:29 UTC. --
Dec 14 17:37:43 umbrel systemd[1]: Starting External Storage SDcard Updater...
Dec 14 17:37:43 umbrel external storage updater[904]: Checking if SD card Umbrel is newer than external storage...
Dec 14 17:37:44 umbrel external storage updater[904]: No, SD version is not newer, exiting.
Dec 14 17:37:44 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
1904 bytes (1.9 kB, 1.9 KiB) copied, 0.000190068 s, 10.0 MB/s
backup/
backup/.padding
Uploading backup...
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (7) Can't complete SOCKS5 connection to 0.0.0.0:0. (6)
Got signal: backup
Deriving keys...
Creating backup...
1+0 records in
1+0 records out
3999 bytes (4.0 kB, 3.9 KiB) copied, 0.0112604 s, 355 kB/s
backup/
backup/.padding
Uploading backup...
Got signal:
Got signal:
Got signal: debug
Docker containers
NAMES                     STATUS
bitcoin_server_1          Up 22 minutes
bitcoin_app_proxy_1       Up 22 minutes
bitcoin_bitcoind_1        Up 22 minutes
bitcoin_tor_server_1      Up 22 minutes
bitcoin_tor_1             Up 22 minutes
electrs_app_1             Up 25 minutes
mempool_mariadb_1         Up 25 minutes
mempool_tor_server_1      Up 25 minutes
mempool_app_proxy_1       Up 25 minutes
mempool_api_1             Up 25 minutes
mempool_web_1             Up 25 minutes
lightning_lnd_1           Up 21 minutes
lightning_tor_server_1    Up 25 minutes
lightning_app_proxy_1     Up 25 minutes
lightning_app_1           Up 25 minutes
lightning_tor_1           Up 25 minutes
electrs_app_proxy_1       Up 25 minutes
electrs_electrs_1         Up 22 minutes
electrs_tor_1             Up 25 minutes
electrs_tor_server_1      Up 25 minutes
thunderhub_app_proxy_1    Up 25 minutes
thunderhub_web_1          Up 25 minutes
thunderhub_tor_server_1   Up 25 minutes
nginx                     Up 26 minutes
dashboard                 Up 26 minutes
manager                   Up 26 minutes
auth                      Up 26 minutes
tor_server                Up 26 minutes
tor_proxy                 Up 26 minutes
Umbrel logs
manager      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:28 GMT] "GET /v1/account/token?token=db917366cec110114f3b405283cdf3157d0ee1895c90acd9a8821c7833b3cf9d HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | ::ffff:10.21.21.2 - - [Wed, 14 Dec 2022 18:04:28 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:29 GMT] "GET /v1/account/token?token=db917366cec110114f3b405283cdf3157d0ee1895c90acd9a8821c7833b3cf9d HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | ::ffff:10.21.21.2 - - [Wed, 14 Dec 2022 18:04:29 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:30 GMT] "GET /v1/account/token?token=db917366cec110114f3b405283cdf3157d0ee1895c90acd9a8821c7833b3cf9d HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      | ::ffff:10.21.21.2 - - [Wed, 14 Dec 2022 18:04:31 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:31 GMT] "GET /v1/account/token?token=db917366cec110114f3b405283cdf3157d0ee1895c90acd9a8821c7833b3cf9d HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
manager      |
manager      | ::ffff:10.21.21.2 - - [Wed, 14 Dec 2022 18:04:32 GMT] "GET /v1/system/debug-result HTTP/1.0" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
manager      |
manager      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:33 GMT] "GET /v1/account/token?token=db917366cec110114f3b405283cdf3157d0ee1895c90acd9a8821c7833b3cf9d HTTP/1.1" 200 16 "-" "app-proxy/0.0.1"
manager      |
Tor Proxy logs
tor_proxy    | Dec 14 18:04:09.000 [warn]  40 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy    | Dec 14 18:04:09.000 [warn]  1 connections died in state handshaking (TLS) with SSL state SSLv3/TLS write client hello in HANDSHAKE
tor_proxy    | Dec 14 18:04:09.000 [warn] Problem bootstrapping. Stuck at 30% (loading_status): Loading networkstatus consensus. (Connection timed out; TIMEOUT; count 43; recommendation warn; host 1B3E48D75E7F7E61D1B9BBE24BA15A38B454380D at 142.112.207.147:9001)
tor_proxy    | Dec 14 18:04:09.000 [warn] 42 connections have failed:
tor_proxy    | Dec 14 18:04:09.000 [warn]  41 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy    | Dec 14 18:04:13.000 [warn] Problem bootstrapping. Stuck at 30% (loading_status): Loading networkstatus consensus. (Connection timed out; TIMEOUT; count 44; recommendation warn; host 210E9B4AE14D78627105EEDBDA8D2C3EFA64D482 at 50.35.22.178:49092)
tor_proxy    | Dec 14 18:04:13.000 [warn] 43 connections have failed:
tor_proxy    | Dec 14 18:04:13.000 [warn]  42 connections died in state connect()ing with SSL state (No SSL object)
tor_proxy    | Dec 14 18:04:13.000 [warn]  1 connections died in state handshaking (TLS) with SSL state SSLv3/TLS write client hello in HANDSHAKE
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_app_proxy_1, bitcoin_bitcoind_1, bitcoin_tor_server_1, bitcoin_tor_1
app_proxy_1   | Validating token: db917366cec1 ...
server_1      | umbrel-middleware
server_1      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:36 GMT] "GET /v1/bitcoind/info/stats HTTP/1.1" 304 - "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
server_1      |
server_1      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:37 GMT] "GET /v1/bitcoind/info/sync HTTP/1.1" 200 88 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
server_1      |
server_1      | ::ffff:10.21.0.11 - - [Wed, 14 Dec 2022 18:04:38 GMT] "GET /v1/bitcoind/info/sync HTTP/1.1" 200 88 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:107.0) Gecko/20100101 Firefox/107.0"
server_1      |
bitcoind_1    | 2022-12-14T17:43:06Z Loading addresses from DNS seed seed.bitcoin.sprovoost.nl.
bitcoind_1    | 2022-12-14T17:43:06Z Loading addresses from DNS seed seed.bitcoin.sipa.be.
bitcoind_1    | 2022-12-14T17:43:06Z 0 addresses found from DNS seeds
bitcoind_1    | 2022-12-14T17:43:06Z dnsseed thread exit
bitcoind_1    | 2022-12-14T17:43:06Z init message: Done loading
bitcoind_1    | 2022-12-14T17:43:06Z addcon thread start
bitcoind_1    | 2022-12-14T17:43:06Z msghand thread start
bitcoind_1    | 2022-12-14T17:43:06Z opencon thread start
bitcoind_1    | 2022-12-14T17:44:08Z Adding fixed seeds as 60 seconds have passed and addrman is empty
bitcoind_1    | 2022-12-14T17:44:08Z Added 790 fixed seeds from reachable networks.
tor_1         | Dec 14 18:03:36.000 [warn]  84 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:36.000 [warn] Problem bootstrapping. Stuck at 45% (requesting_descriptors): Asking for relay descriptors. (Connection timed out; TIMEOUT; count 86; recommendation warn; host 56927E61B51E6F363FB55498150A6DDFCF7077F2 at 95.216.33.58:443)
tor_1         | Dec 14 18:03:36.000 [warn] 85 connections have failed:
tor_1         | Dec 14 18:03:36.000 [warn]  85 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:36.000 [warn] Problem bootstrapping. Stuck at 45% (requesting_descriptors): Asking for relay descriptors. (Connection timed out; TIMEOUT; count 87; recommendation warn; host 78E42C5EA3FC4C5606B3ACF5623DE25FE6B5F167 at 46.41.137.28:9001)
tor_1         | Dec 14 18:03:36.000 [warn] 86 connections have failed:
tor_1         | Dec 14 18:03:36.000 [warn]  86 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:36.000 [warn] Problem bootstrapping. Stuck at 45% (requesting_descriptors): Asking for relay descriptors. (Connection timed out; TIMEOUT; count 88; recommendation warn; host FFBBBA7F1C73B07A80F5AF759A2AEF481F143896 at 65.108.42.103:443)
tor_1         | Dec 14 18:03:36.000 [warn] 87 connections have failed:
tor_1         | Dec 14 18:03:36.000 [warn]  87 connections died in state connect()ing with SSL state (No SSL object)
electrs
Attaching to electrs_app_1, electrs_app_proxy_1, electrs_electrs_1, electrs_tor_1, electrs_tor_server_1
app_1         |
app_1         |
app_1         |
app_1         | Wed, 14 Dec 2022 17:39:32 GMT morgan deprecated morgan(options): use morgan("default", options) instead at app.js:28:9
app_1         | Wed, 14 Dec 2022 17:39:32 GMT morgan deprecated default format: use combined format at app.js:28:9
tor_1         | Dec 14 18:01:37.000 [warn]  33 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:01:58.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection refused; CONNECTREFUSED; count 35; recommendation warn; host 3F38C17C11B43562766B50A95366B021CBCC7ADA at 198.98.62.79:9000)
tor_1         | Dec 14 18:01:58.000 [warn] 34 connections have failed:
tor_1         | Dec 14 18:01:58.000 [warn]  34 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:02:51.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 36; recommendation warn; host 9695DFC35FFEB861329B9F1AB04C46397020CE31 at 128.31.0.39:9101)
tor_1         | Dec 14 18:02:51.000 [warn] 35 connections have failed:
tor_1         | Dec 14 18:02:51.000 [warn]  35 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:02:51.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 37; recommendation warn; host C65DE4A7380BACAC9478561959DC59DD1FF5E1B9 at 103.102.46.57:443)
tor_1         | Dec 14 18:02:51.000 [warn] 36 connections have failed:
tor_1         | Dec 14 18:02:51.000 [warn]  36 connections died in state connect()ing with SSL state (No SSL object)
electrs_1     | [2022-12-14T18:04:30.789Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:32.028Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:33.040Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:34.246Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:35.255Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:36.547Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:37.560Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:38.565Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:39.571Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
electrs_1     | [2022-12-14T18:04:40.582Z INFO  electrs::daemon] waiting for 1 blocks to download (IBD)
lightning
Attaching to lightning_lnd_1, lightning_tor_server_1, lightning_app_proxy_1, lightning_app_1, lightning_tor_1
app_1         | [backup-monitor] Error: Proxy connection timed out
app_1         | [backup-monitor] Sleeping...
app_1         | LND already unlocked!
app_1         | [backup-monitor] Checking channel backup...
app_1         | [backup-monitor] Channel backup has changed, backing up!
tor_1         | Dec 14 18:03:01.000 [warn]  38 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:03.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 40; recommendation warn; host EE91DEB597FC20A55347E86E1DCB818734BE6C59 at 193.105.134.187:9001)
tor_1         | Dec 14 18:03:03.000 [warn] 39 connections have failed:
tor_1         | Dec 14 18:03:03.000 [warn]  39 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:34.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 41; recommendation warn; host BD6A829255CB08E66FBE7D3748363586E46B3810 at 171.25.193.9:80)
tor_1         | Dec 14 18:03:34.000 [warn] 40 connections have failed:
tor_1         | Dec 14 18:03:34.000 [warn]  40 connections died in state connect()ing with SSL state (No SSL object)
tor_1         | Dec 14 18:03:34.000 [warn] Problem bootstrapping. Stuck at 5% (conn): Connecting to a relay. (Connection timed out; TIMEOUT; count 42; recommendation warn; host F475E5987E44A2B7B143A2BEE3F8128EEFD7E5A3 at 188.68.45.180:9001)
tor_1         | Dec 14 18:03:34.000 [warn] 41 connections have failed:
tor_1         | Dec 14 18:03:34.000 [warn]  41 connections died in state connect()ing with SSL state (No SSL object)
lnd_1         | 2022-12-14 17:43:16.739 [INF] HSWC: Restoring in-memory circuit state from disk
lnd_1         | 2022-12-14 17:43:16.740 [INF] HSWC: Payment circuits loaded: num_pending=0, num_open=0
lnd_1         | 2022-12-14 17:43:16.749 [INF] HSWC: Trimming open circuits for chan_id=713393:810:0, start_htlc_id=0
lnd_1         | 2022-12-14 17:43:16.750 [INF] HSWC: Trimming open circuits for chan_id=712289:738:1, start_htlc_id=1
lnd_1         | 2022-12-14 17:43:16.750 [INF] HSWC: Trimming open circuits for chan_id=711871:2176:1, start_htlc_id=2
lnd_1         | 2022-12-14 17:43:16.751 [INF] HSWC: Trimming open circuits for chan_id=713437:2170:0, start_htlc_id=0
lnd_1         | 2022-12-14 17:43:16.789 [INF] LTND: Channel backup proxy channel notifier starting
lnd_1         | 2022-12-14 17:43:16.790 [INF] ATPL: Instantiating autopilot with active=false, max_channels=5, allocation=0.600000, min_chan_size=20000, max_chan_size=16777215, private=false, min_confs=1, conf_target=3
lnd_1         | 2022-12-14 17:43:16.791 [INF] LTND: We're not running within systemd or the service type is not 'notify'
lnd_1         | 2022-12-14 17:43:16.797 [INF] LTND: Waiting for chain backend to finish sync, start_height=732647
mempool
Attaching to mempool_mariadb_1, mempool_tor_server_1, mempool_app_proxy_1, mempool_api_1, mempool_web_1
api_1         | Dec 14 17:41:48 [97] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1         | Dec 14 17:41:48 [97] ERR: Electrum error: {}
api_1         | Dec 14 17:42:01 [97] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1         | Dec 14 17:42:01 [97] ERR: Electrum error: {}
api_1         | Dec 14 17:42:16 [97] INFO: Disconnected from Electrum Server at 10.21.21.10:50001
api_1         | Dec 14 17:42:16 [97] ERR: Electrum error: {}
api_1         | Dec 14 17:42:32 [97] WARN: runMainLoop error: Loading block index…. Retrying in 10 sec.
api_1         | Dec 14 17:42:42 [97] WARN: runMainLoop error: Loading block index…. Retrying in 20 sec.
api_1         | Dec 14 17:43:02 [97] WARN: runMainLoop error: Verifying blocks…. Retrying in 40 sec.
api_1         | Dec 14 17:43:42 [97] NOTICE: The mempool is now in sync!
mariadb_1     | 2022-12-14 17:39:01 0 [Note] Plugin 'FEEDBACK' is disabled.
mariadb_1     | 2022-12-14 17:39:01 0 [Note] Server socket created on IP: '::'.
mariadb_1     | 2022-12-14 17:39:01 0 [Warning] 'proxies_priv' entry '@% root@b4082fa4f425' ignored in --skip-name-resolve mode.
mariadb_1     | 2022-12-14 17:39:01 0 [Note] Reading of all Master_info entries succeeded
mariadb_1     | 2022-12-14 17:39:01 0 [Note] Added new Master_info '' to hash table
mariadb_1     | 2022-12-14 17:39:01 0 [Note] mysqld: ready for connections.
mariadb_1     | 2022-12-14 17:39:01 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.27' (This connection closed normally without authentication)
mariadb_1     | 2022-12-14 17:39:02 4 [Warning] Aborted connection 4 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
mariadb_1     | 2022-12-14 17:39:03 0 [Note] InnoDB: Buffer pool(s) load completed at 221214 17:39:03
thunderhub
Attaching to thunderhub_app_proxy_1, thunderhub_web_1, thunderhub_tor_server_1
web_1         | {
web_1         |   timestamp: '2022-12-14T17:40:13.735Z'
web_1         | }
web_1         | {
web_1         |   timestamp: '2022-12-14T17:40:13.737Z'
web_1         | }
==== Result ====
