I have Umbrel running on my Raspberry Pi 4 8GB with a 1TB SSD attached. I’m on the home screen for Umbrel and there are no apps. Also when I open the app store it is completely blank.
What could I be doing wrong?
Can you post a picture of what your seeing your setting on your screen?
You can also SSH and run this command to get your logs
sudo ~/umbrel/scripts/debug
There is instructions for doing that in the
Will definitely want to take a look in your logs to see what’s causing that
0.5.3
v0.5.3
Revision : d03115
Serial : 10000000b6441faa
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
temp=34.5’C
throttled=0x0
Mem: 7.8G 283M 4.6G 8.0M 2.9G 7.4G
Swap: 4.1G 0B 4.1G
total: 3.6%
system: 3.6%
2022-11-02 15:18:28 Memory monitor running!
/dev/root 118G 2.8G 110G 3% /
/dev/sda1 916G 5.3G 865G 1% /home/umbrel/umbrel
Nov 02 15:18:28 umbrel umbrel startup[1212]: ============== UMBREL ================
Nov 02 15:18:28 umbrel umbrel startup[1212]: ======================================
Nov 02 15:18:28 umbrel umbrel startup[1212]: Setting environment variables…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting karen…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting status monitors…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting memory monitor…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting backup monitor…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting decoy backup trigger…
Nov 02 15:18:28 umbrel umbrel startup[1212]: Starting Docker services…
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating network “umbrel_main_network” with the default driver
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating volume “umbrel_jwt-public-key” with default driver
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating volume “umbrel_jwt-private-key” with default driver
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating auth …
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating manager …
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating tor_proxy …
Nov 02 15:18:30 umbrel umbrel startup[1212]: Creating dashboard …
Nov 02 15:18:32 umbrel umbrel startup[1212]: Creating manager … done
Nov 02 15:18:32 umbrel umbrel startup[1212]: Creating auth … done
Nov 02 15:18:32 umbrel umbrel startup[1212]: Creating dashboard … done
Nov 02 15:18:32 umbrel umbrel startup[1212]: Creating nginx …
Nov 02 15:18:32 umbrel umbrel startup[1212]: Creating tor_proxy … done
Nov 02 15:18:33 umbrel umbrel startup[1212]: Creating nginx … done
Nov 02 15:18:34 umbrel umbrel startup[1212]: Removing status server iptables entry…
Nov 02 15:18:34 umbrel umbrel startup[1212]: Removed existing iptables entry.
Nov 02 15:18:34 umbrel umbrel startup[1212]: Starting installed apps…
Nov 02 15:18:34 umbrel umbrel startup[1212]: Umbrel is now accessible at
Nov 02 15:18:34 umbrel umbrel startup[1212]: http://umbrel.local
Nov 02 15:18:34 umbrel umbrel startup[1212]: http://192.168.0.198
Nov 02 15:18:34 umbrel systemd[1]: Started Umbrel Startup Service.
Nov 02 15:22:13 umbrel passwd[4182]: pam_unix(passwd:chauthtok): password changed for umbrel
Nov 02 15:17:10 umbrel external storage mounter[473]: /dev/sda: calling ioctl to re-read partition table: Success
Nov 02 15:17:10 umbrel external storage mounter[473]: mke2fs 1.44.5 (15-Dec-2018)
Nov 02 15:17:10 umbrel external storage mounter[473]: Creating filesystem with 244190208 4k blocks and 61054976 inodes
Nov 02 15:17:10 umbrel external storage mounter[473]: Filesystem UUID: 7a795b8e-0936-4f65-8481-c4cee5f49589
Nov 02 15:17:10 umbrel external storage mounter[473]: Superblock backups stored on blocks:
Nov 02 15:17:10 umbrel external storage mounter[473]: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
Nov 02 15:17:10 umbrel external storage mounter[473]: 4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
Nov 02 15:17:10 umbrel external storage mounter[473]: 102400000, 214990848
Nov 02 15:17:10 umbrel external storage mounter[473]: [65B blob data]
Nov 02 15:17:10 umbrel external storage mounter[473]: [62B blob data]
Nov 02 15:17:12 umbrel external storage mounter[473]: Creating journal (262144 blocks): done
Nov 02 15:17:17 umbrel external storage mounter[473]: [99B blob data]
Nov 02 15:17:17 umbrel external storage mounter[473]: Mounting partition…
Nov 02 15:17:17 umbrel external storage mounter[473]: Copying Umbrel install to external storage…
Nov 02 15:17:17 umbrel external storage mounter[473]: Copying Docker data directory to external storage…
Nov 02 15:18:18 umbrel external storage mounter[473]: Bind mounting external storage over local Umbrel installation…
Nov 02 15:18:18 umbrel external storage mounter[473]: Bind mounting external storage over local Docker data dir…
Nov 02 15:18:18 umbrel external storage mounter[473]: Bind mounting external storage to /swap
Nov 02 15:18:18 umbrel external storage mounter[473]: Bind mounting SD card root at /sd-card…
Nov 02 15:18:18 umbrel external storage mounter[473]: Checking Umbrel root is now on external storage…
Nov 02 15:18:22 umbrel external storage mounter[473]: Checking /var/lib/docker is now on external storage…
Nov 02 15:18:22 umbrel external storage mounter[473]: Checking /swap is now on external storage…
Nov 02 15:18:22 umbrel external storage mounter[473]: Setting up swapfile
Nov 02 15:18:22 umbrel external storage mounter[473]: rm: cannot remove ‘/swap/swapfile’: No such file or directory
Nov 02 15:18:22 umbrel external storage mounter[473]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Nov 02 15:18:22 umbrel external storage mounter[473]: no label, UUID=801c855e-7f93-4274-9a81-f0e8c18f1ba3
Nov 02 15:18:22 umbrel external storage mounter[473]: Checking SD Card root is bind mounted at /sd-root…
Nov 02 15:18:22 umbrel external storage mounter[473]: Starting external drive mount monitor…
Nov 02 15:18:22 umbrel external storage mounter[473]: Mount script completed successfully!
Nov 02 15:18:22 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Wed 2022-11-02 15:17:01 UTC, end at Wed 2022-11-02 15:22:13 UTC. –
Nov 02 15:18:25 umbrel systemd[1]: Starting External Storage SDcard Updater…
Nov 02 15:18:25 umbrel external storage updater[1135]: Checking if SD card Umbrel is newer than external storage…
Nov 02 15:18:25 umbrel external storage updater[1135]: No, SD version is not newer, exiting.
Nov 02 15:18:25 umbrel systemd[1]: Started External Storage SDcard Updater.
Got signal:
karen is getting triggered!
Got signal:
Got signal: change-password
Got signal: debug
NAMES STATUS
nginx Up 4 minutes
dashboard Up 4 minutes
manager Up 4 minutes
auth Up 4 minutes
tor_proxy Up 4 minutes
Attaching to manager
manager | at Object.listDirsInDir (/app/services/disk.js:77:23)
manager | at Object.get (/app/logic/apps.js:118:33)
manager | at async /app/routes/v1/apps.js:16:18
manager | at async /app/utils/safeHandler.js:8:14 {
manager | errno: -2,
manager | syscall: ‘scandir’,
manager | code: ‘ENOENT’,
manager | path: ‘/repos/https—github-com-getumbrel-umbrel-apps-git’
manager | }
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/apps HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/system/is-sd-card-failing HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/system/memory HTTP/1.0” 200 84 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/system/storage HTTP/1.0” 200 88 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/system/temperature HTTP/1.0” 200 2 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
manager | ::ffff:10.21.21.2 - - [Wed, 02 Nov 2022 15:22:40 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
So your date/time is wrong, whitch is going to prevent anything that uses ssl certs from loading. I wouldn’t think that would cause this, but it’s all I see here so here’s how to fix it
https://www.instructables.com/How-to-Set-Time-and-Date-in-Raspberry-Pi/?amp_page=true
Though your pi should sync its time everytime it boots, I’m assuming it has restarted in the passed 101 days?
Just got the pi board a couple days ago. I updated the date and timezone settings through SSH but still no apps. This is the new debug log umbrel-1676229261900-debug.log (11.1 KB) any other suggestions?
