Hey guys I have no access to my node sine 2 days, umbrel.local / ip does not work to access. What else can I try ? Apprecitate any help
No change in the network configuration?
Are there two devices using the same IP?
Nothing changed, also no system update. No there are not 2 devices. Checkef with ip scanner. The last thing I have changed was the tor remote setting. I see the ip and mac adress in my router settings. I tried with terminal ssh and I do not receive any command to put my password…!
I’m sure you have already done a complete shutdown of the node then powered it back.
Yeah many times, next thing I will try is reflashing the sd maybe ?
Let me know how that turns out.
Unfortunately it did not work with the reflash - error: NSURLErrorTimedOut
I have no more options, cant reach even with terminal
Please help meeeeee
Could it be the SD card upside down?
No unfortunately not…
Have I suggested reflashing to Pi OS and see if that loads? If the basic Pi OS doesn’t load, maybe it’s the hardware.
Could be. Need to check it out once I have time. But what I cant believe that nobody is helping out besides you …. There must be a guide since I am not the only having this issue. I see more ppl got the same problem since the latesr update.
Same 4 me I am tired of this drabacks. Can anyone help…
How can I check that, do I need to plug a display for that ?
