Good morning, guys I have an issue, after my Umbrel finished syncing I sent yesterday some sats, the balance was showing perfectly but now it is blank, it also seems like I lost connections to apps, I can’t access/log thunderhub or bluewallet
This is when I try to use the Bluewallet app:
I also noticed that the my node seems to be freeze, it shows 100 sync but it is not syncing anymore.
These are my logs:
0.3.14
Flashed OS version
v0.3.10
Raspberry Pi Model
Revision : c03112
Serial : 100000001e05dd36
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Feb 25 2021 12:10:40
Copyright (c) 2012 Broadcom
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start)
Temperature
temp=48.2’C
Throttling
throttled=0x0
Mem: 3.8G 988M 789M 4.0M 2.0G 2.7G
Swap: 4.1G 414M 3.7G
total: 26.1%
bitcoin: 11.5%
electrs: 10.7%
lnd: 4.2%
tor: 0.9%
thunderhub: 0%
system: 0%
bluewallet: 0%
Memory monitor logs
2021-06-30 16:02:58 Warning memory usage at 92%
2021-06-30 16:06:59 Warning memory usage at 91%
2021-06-30 16:09:59 Warning memory usage at 91%
2021-06-30 16:14:00 Warning memory usage at 91%
2021-06-30 16:18:01 Warning memory usage at 91%
2021-06-30 16:26:02 Warning memory usage at 91%
2021-06-30 16:28:25 Memory monitor running!
2021-07-01 04:17:22 Memory monitor running!
2021-07-01 10:41:52 Memory monitor running!
2021-07-01 10:46:27 Memory monitor running!
/dev/root 59G 2.8G 54G 5% /
/dev/sda1 938G 494G 397G 56% /home/umbrel/umbrel
Startup service logs
Jul 01 10:46:32 umbrel umbrel startup[1476]: manager is up-to-date
Jul 01 10:46:32 umbrel umbrel startup[1476]: Starting dashboard … done
Jul 01 10:46:32 umbrel umbrel startup[1476]: lnd is up-to-date
Jul 01 10:46:32 umbrel umbrel startup[1476]: Starting nginx …
Jul 01 10:46:33 umbrel umbrel startup[1476]: Starting nginx … done
Jul 01 10:46:33 umbrel umbrel startup[1476]: Starting bitcoin …
Jul 01 10:51:15 umbrel umbrel startup[1476]: Starting bitcoin … done
Jul 01 10:51:15 umbrel umbrel startup[1476]: Starting middleware …
Jul 01 10:51:15 umbrel umbrel startup[1476]: Starting neutrino-switcher …
Jul 01 10:51:17 umbrel umbrel startup[1476]: Starting neutrino-switcher … done
Jul 01 10:51:17 umbrel umbrel startup[1476]: Starting middleware … done
Jul 01 10:51:17 umbrel umbrel startup[1476]: Removing status server iptables entry…
Jul 01 10:51:17 umbrel umbrel startup[1476]: Removed existing iptables entry.
Jul 01 10:51:17 umbrel umbrel startup[1476]: Starting installed apps…
Jul 01 10:51:17 umbrel umbrel startup[1476]: Starting app bluewallet…
Jul 01 10:51:17 umbrel umbrel startup[1476]: Starting app thunderhub…
Jul 01 10:51:20 umbrel umbrel startup[1476]: Creating thunderhub_web_1 …
Jul 01 10:51:20 umbrel umbrel startup[1476]: Creating bluewallet_redis_1 …
Jul 01 10:51:22 umbrel umbrel startup[1476]: Creating bluewallet_redis_1 … done
Jul 01 10:51:22 umbrel umbrel startup[1476]: Creating bluewallet_lndhub_1 …
Jul 01 10:51:23 umbrel umbrel startup[1476]: Creating thunderhub_web_1 … done
Jul 01 10:51:25 umbrel umbrel startup[1476]: Creating bluewallet_lndhub_1 … done
Jul 01 10:51:25 umbrel umbrel startup[1476]: Umbrel is now accessible at
Jul 01 10:51:25 umbrel umbrel startup[1476]: http://umbrel.local
Jul 01 10:51:25 umbrel umbrel startup[1476]: http://192.168.86.96
Jul 01 10:51:25 umbrel systemd[1]: Started Umbrel Startup Service.
Jul 01 10:52:33 umbrel passwd[4591]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 01 11:25:28 umbrel passwd[30173]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 01 11:26:25 umbrel passwd[30915]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
– Logs begin at Thu 2021-07-01 10:41:28 UTC, end at Thu 2021-07-01 12:39:18 UTC. –
Jul 01 10:46:05 umbrel systemd[1]: Starting External Storage Mounter…
Jul 01 10:46:05 umbrel external storage mounter[496]: Running external storage mount script…
Jul 01 10:46:05 umbrel external storage mounter[496]: Found device “TEAM T25 3X2001T”
Jul 01 10:46:05 umbrel external storage mounter[496]: Blacklisting USB device IDs against UAS driver…
Jul 01 10:46:05 umbrel external storage mounter[496]: Rebinding USB drivers…
Jul 01 10:46:06 umbrel external storage mounter[496]: Checking USB devices are back…
Jul 01 10:46:06 umbrel external storage mounter[496]: Waiting for USB devices…
Jul 01 10:46:07 umbrel external storage mounter[496]: Waiting for USB devices…
Jul 01 10:46:08 umbrel external storage mounter[496]: Checking if the device is ext4…
Jul 01 10:46:08 umbrel external storage mounter[496]: Yes, it is ext4
Jul 01 10:46:10 umbrel external storage mounter[496]: Checking if device contains an Umbrel install…
Jul 01 10:46:10 umbrel external storage mounter[496]: Yes, it contains an Umbrel install
Jul 01 10:46:10 umbrel external storage mounter[496]: Bind mounting external storage over local Umbrel installation…
Jul 01 10:46:10 umbrel external storage mounter[496]: Bind mounting external storage over local Docker data dir…
Jul 01 10:46:10 umbrel external storage mounter[496]: Bind mounting external storage to /swap
Jul 01 10:46:10 umbrel external storage mounter[496]: Bind mounting SD card root at /sd-card…
Jul 01 10:46:10 umbrel external storage mounter[496]: Checking Umbrel root is now on external storage…
Jul 01 10:46:11 umbrel external storage mounter[496]: Checking /var/lib/docker is now on external storage…
Jul 01 10:46:11 umbrel external storage mounter[496]: Checking /swap is now on external storage…
Jul 01 10:46:11 umbrel external storage mounter[496]: Setting up swapfile
Jul 01 10:46:12 umbrel external storage mounter[496]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jul 01 10:46:12 umbrel external storage mounter[496]: no label, UUID=8f569cd2-61b6-44fd-8b24-291449c09ac4
Jul 01 10:46:12 umbrel external storage mounter[496]: Checking SD Card root is bind mounted at /sd-root…
Jul 01 10:46:12 umbrel external storage mounter[496]: Starting external drive mount monitor…
Jul 01 10:46:12 umbrel external storage mounter[496]: Mount script completed successfully!
Jul 01 10:46:12 umbrel systemd[1]: Started External Storage Mounter.
Jul 01 10:46:26 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jul 01 10:46:26 umbrel external storage updater[1389]: Checking if SD card Umbrel is newer than external storage…
Jul 01 10:46:27 umbrel external storage updater[1389]: No, SD version is not newer, exiting.
Jul 01 10:46:27 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Stopping app thunderhub…
Stopping app bluewallet…
Stopping thunderhub_web_1 …
Stopping bluewallet_lndhub_1 …
Stopping bluewallet_redis_1 …
Stopping bluewallet_lndhub_1 … done
Stopping thunderhub_web_1 … done
Removing thunderhub_web_1 …
Removing thunderhub_web_1 … done
Going to remove thunderhub_web_1
Stopping bluewallet_redis_1 … done
Removing bluewallet_lndhub_1 …
Removing bluewallet_redis_1 …
Removing bluewallet_redis_1 … done
Removing bluewallet_lndhub_1 … done
Going to remove bluewallet_lndhub_1, bluewallet_redis_1
Stopping Docker services…
Stopping middleware …
Stopping bitcoin …
Stopping nginx …
Stopping lnd …
Stopping manager …
Stopping tor …
Stopping electrs …
Stopping dashboard …
Stopping middleware … done
Stopping lnd … done
Stopping bitcoin … done
Stopping nginx … done
Stopping dashboard … done
Stopping manager … done
Stopping tor … done
Got signal: change-password
karen is getting triggered!
Got signal: debug
Debug result file generated
Got signal: debug
Docker containers
NAMES STATUS
bluewallet_lndhub_1 Restarting (3) 53 seconds ago
bluewallet_redis_1 Up 2 hours
thunderhub_web_1 Up 2 hours
middleware Up 2 hours
bitcoin Up 2 hours
nginx Up 2 hours
lnd Up 16 seconds
manager Up 2 hours
tor Up 2 hours
electrs Up 2 hours
dashboard Up 2 hours
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-07-01T11:12:11Z Socks5() connect to 79.136.59.210:8333 failed: general failure
bitcoin | 2021-07-01T11:14:30Z Socks5() connect to 194.39.101.10:8333 failed: general failure
bitcoin | 2021-07-01T11:16:40Z Socks5() connect to 2601:cd:c100:48d0::262b:8333 failed: general failure
bitcoin | 2021-07-01T11:20:41Z FlushStateToDisk: write coins cache to disk (194514 coins, 26986kB) started
bitcoin | 2021-07-01T11:20:41Z FlushStateToDisk: write coins cache to disk (194514 coins, 26986kB) completed (0.19s)
bitcoin | 2021-07-01T11:23:35Z Potential stale tip detected, will try using extra outbound peer (last tip update: 1891 seconds ago)
bitcoin | 2021-07-01T11:24:21Z New outbound peer connected: version: 70015, blocks=689300, peer=19 (full-relay)
bitcoin | 2021-07-01T11:34:05Z Potential stale tip detected, will try using extra outbound peer (last tip update: 2521 seconds ago)
bitcoin | 2021-07-01T11:34:07Z New outbound peer connected: version: 70016, blocks=689300, peer=21 (full-relay)
bitcoin | 2021-07-01T11:36:26Z Socks5() connect to 91.42.154.210:8333 failed: general failure
bitcoin | 2021-07-01T11:38:12Z Socks5() connect to 2002:c6c8:2bd7::c6c8:2bd7:8333 failed: general failure
bitcoin | 2021-07-01T11:44:35Z Potential stale tip detected, will try using extra outbound peer (last tip update: 3151 seconds ago)
bitcoin | 2021-07-01T11:44:36Z Socks5() connect to 2a00:1370:8125:51c2:9bcb:ad05:3f32:8101:8333 failed: general failure
bitcoin | 2021-07-01T11:44:59Z New outbound peer connected: version: 70015, blocks=689300, peer=23 (full-relay)
bitcoin | 2021-07-01T11:48:03Z Socks5() connect to 195.62.193.162:8333 failed: general failure
bitcoin | 2021-07-01T11:55:05Z Potential stale tip detected, will try using extra outbound peer (last tip update: 3781 seconds ago)
bitcoin | 2021-07-01T11:55:08Z Socks5() connect to 186.106.188.8:8333 failed: connection refused
bitcoin | 2021-07-01T11:55:09Z New outbound peer connected: version: 70015, blocks=689300, peer=27 (full-relay)
bitcoin | 2021-07-01T11:55:42Z New outbound peer connected: version: 70016, blocks=689300, peer=29 (full-relay)
bitcoin | 2021-07-01T12:02:36Z Socks5() connect to 95.153.31.70:8333 failed: general failure
bitcoin | 2021-07-01T12:05:35Z Potential stale tip detected, will try using extra outbound peer (last tip update: 4411 seconds ago)
bitcoin | 2021-07-01T12:06:50Z New outbound peer connected: version: 70016, blocks=689300, peer=31 (full-relay)
bitcoin | 2021-07-01T12:16:06Z Potential stale tip detected, will try using extra outbound peer (last tip update: 5042 seconds ago)
bitcoin | 2021-07-01T12:16:10Z New outbound peer connected: version: 70015, blocks=689300, peer=32 (full-relay)
bitcoin | 2021-07-01T12:22:44Z Socks5() connect to 67:4f8:160:22cf::2:8333 failed: general failure
bitcoin | 2021-07-01T12:26:36Z Potential stale tip detected, will try using extra outbound peer (last tip update: 5672 seconds ago)
bitcoin | 2021-07-01T12:27:21Z New outbound peer connected: version: 70016, blocks=689300, peer=33 (full-relay)
bitcoin | 2021-07-01T12:31:47Z New outbound peer connected: version: 70016, blocks=689300, peer=34 (full-relay)
bitcoin | 2021-07-01T12:37:06Z Potential stale tip detected, will try using extra outbound peer (last tip update: 6302 seconds ago)
bitcoin | 2021-07-01T12:37:27Z New outbound peer connected: version: 70016, blocks=689300, peer=36 (full-relay)
LND logs
Attaching to lnd
lnd | 2021-07-01 12:38:15.963 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2021-07-01 12:38:15.963 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2021-07-01 12:38:16.813 [INF] CHDB: Checking for schema update: latest_version=20, db_version=20
lnd | 2021-07-01 12:38:16.814 [INF] LTND: Database now open (time_to_open=850.605608ms)!
lnd | 2021-07-01 12:38:16.851 [INF] RPCS: Password RPC server listening on 0.0.0.0:10009
lnd | 2021-07-01 12:38:16.851 [INF] RPCS: Password gRPC proxy started at 0.0.0.0:8080
lnd | 2021-07-01 12:38:16.851 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
lnd | 2021-07-01 12:39:13.782 [INF] LNWL: Opened wallet
lnd | 2021-07-01 12:39:13.975 [INF] CHRE: Primary chain is set to: bitcoin
lnd | 2021-07-01 12:39:13.991 [INF] CHRE: Initializing bitcoind backed fee estimator in CONSERVATIVE mode
lnd | 2021-07-01 12:39:13.991 [INF] LNWL: Started listening for bitcoind block notifications via ZMQ on 10.21.21.8:28332
lnd | 2021-07-01 12:39:13.991 [INF] LNWL: Started listening for bitcoind transaction notifications via ZMQ on 10.21.21.8:28333
lnd | 2021-07-01 12:39:16.481 [INF] LNWL: The wallet has been unlocked without a time limit
lnd | 2021-07-01 12:39:16.492 [INF] CHRE: LightningWallet opened
lnd | 2021-07-01 12:39:16.495 [INF] SRVR: Proxying all network traffic via Tor (stream_isolation=false)! NOTE: Ensure the backend node is proxying over Tor as well
lnd | 2021-07-01 12:39:16.501 [INF] HSWC: Restoring in-memory circuit state from disk
lnd | 2021-07-01 12:39:16.502 [INF] HSWC: Payment circuits loaded: num_pending=0, num_open=0
lnd | 2021-07-01 12:39:16.502 [ERR] LTND: unable to create server: alias too large: max is 32, got 39
lnd | 2021-07-01 12:39:16.513 [INF] LTND: Shutdown complete
lnd |
lnd | unable to create server: alias too large: max is 32, got 39
lnd | 2021-07-01 12:39:18.770 [INF] LTND: Version: 0.12.1-beta commit=v0.12.1-beta, build=production, logging=default, debuglevel=info
lnd | 2021-07-01 12:39:18.770 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2021-07-01 12:39:18.770 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2021-07-01 12:39:18.770 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2021-07-01 12:39:19.619 [INF] CHDB: Checking for schema update: latest_version=20, db_version=20
lnd | 2021-07-01 12:39:19.619 [INF] LTND: Database now open (time_to_open=849.188914ms)!
lnd | 2021-07-01 12:39:19.658 [INF] RPCS: Password RPC server listening on 0.0.0.0:10009
lnd | 2021-07-01 12:39:19.659 [INF] RPCS: Password gRPC proxy started at 0.0.0.0:8080
lnd | 2021-07-01 12:39:19.659 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
Tor logs
Attaching to tor
tor | Jul 01 12:08:51.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:09:54.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:10:57.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:12:00.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:13:03.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:14:05.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:15:08.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:16:12.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:17:14.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:18:17.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:19:20.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:20:23.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:21:26.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:22:29.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:23:32.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:24:35.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:25:38.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:26:41.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:27:44.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:28:46.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:29:49.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:30:52.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:31:55.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:32:58.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:34:01.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:35:04.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:36:07.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:37:10.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:38:13.000 [notice] New control connection opened from 10.21.21.9.
tor | Jul 01 12:39:16.000 [notice] New control connection opened from 10.21.21.9.
App logs
bluewallet
lndhub_1 | at processTicksAndRejections (internal/process/task_queues.js:79:11) {
lndhub_1 | code: 12,
lndhub_1 | details: ‘unknown service lnrpc.Lightning’,
lndhub_1 | metadata: Metadata {
lndhub_1 | internalRepr: Map { ‘content-type’ => [Array] },
lndhub_1 | options: {}
lndhub_1 | }
lndhub_1 | }
lndhub_1 | npm ERR! code ELIFECYCLE
lndhub_1 | npm ERR! errno 3
lndhub_1 | npm ERR! lndhub@1.3.3 start: babel-node index.js
lndhub_1 | npm ERR! Exit status 3
lndhub_1 | npm ERR!
lndhub_1 | npm ERR! Failed at the lndhub@1.3.3 start script.
lndhub_1 | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
lndhub_1 |
lndhub_1 | npm ERR! A complete log of this run can be found in:
lndhub_1 | npm ERR! /lndhub/.npm/_logs/2021-07-01T12_38_41_859Z-debug.log
redis_1 | 8:C 01 Jul 2021 10:51:23.063 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
redis_1 | 8:C 01 Jul 2021 10:51:23.063 # Redis version=6.2.2, bits=64, commit=00000000, modified=0, pid=8, just started
redis_1 | 8:C 01 Jul 2021 10:51:23.063 # Configuration loaded
redis_1 | 8:M 01 Jul 2021 10:51:23.065 * monotonic clock: POSIX clock_gettime
redis_1 | 8:M 01 Jul 2021 10:51:23.069 * Running mode=standalone, port=6379.
redis_1 | 8:M 01 Jul 2021 10:51:23.070 # Server initialized
redis_1 | 8:M 01 Jul 2021 10:51:23.070 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add ‘vm.overcommit_memory = 1’ to /etc/sysctl.conf and then reboot or run the command ‘sysctl vm.overcommit_memory=1’ for this to take effect.
redis_1 | 8:M 01 Jul 2021 10:51:23.077 * Loading RDB produced by version 6.2.2
redis_1 | 8:M 01 Jul 2021 10:51:23.077 * RDB age 247 seconds
redis_1 | 8:M 01 Jul 2021 10:51:23.077 * RDB memory usage when created 0.80 Mb
redis_1 | 8:M 01 Jul 2021 10:51:23.077 * DB loaded from disk: 0.001 seconds
redis_1 | 8:M 01 Jul 2021 10:51:23.077 * Ready to accept connections
thunderhub
