Moving from Pi to Ubuntu NUC - is my plan sound?
I want to migrate Umbrel with all data and state to my NUC.
I installed Umbrel in Ubuntu. I have a fresh installation at ~/umbrel that is fully functional at the start screen (this demonstrates that I have the necessary requirements to run the specific version of docker-compose).
Comparing this to my existing Pi installation, I believe I can shut down Umbrel, move the ~/umbrel directory elsewhere as a backup, mount the Pi’s USB drive to ~/umbrel, run ~/umbrel/scripts/start and all will be well.
I could probably also mount the drive somewhere else, like /mnt/umbrel and do the same (scripts/start).
Does this sound like it will work?
I tried this. Umbrel started, bitcoind started, lnd did not.
did you ever figure this out?
I think it’s fair to say I didn’t.
I did a fresh install after copying blockchain to the right location. It still took days to validate so I’m not sure that was very helpful. I then attempted to migrate channels, but they failed to come back on (I now realise that I didn’t have tor set up correctly, as this doesn’t work out of the box).
By the time I restored back to the pi, a few partner channels had forced closed on me.
2/5 will try again one day.
check out this post
