Miningcore MiningCore Mining POOL APP
tenho um notebook Hp Pavilion g4 - 8 RAM HD NORMAL SATA 500GB, Umbrel instalado do zero servidor nada instalado, puro estou em busca de instalar pools, ja instalei PostgreSql+pgAdmin, miningCore Web UI e Bitcoin Cash BCH Node, falta MininCore, mas nao quer instalar no final da instalação estar dando erro app nao quer instalar no umbrel, ja formatei o notebook e tentei instalar puro so o MiningCore, mas nao instala, da o mesmo erro, oque posso fazer pra passar essa etapa e conseguir configurar meus nods no MiningCore UI ?ME AJUDEM ESTOU SO 40 HORAS EM BUSCA DE SOLUÇÃO PLIS, HELP!!!
SEGUE EM ANEXO MEU LOG DO SITEMA, EM TXT, NO BLOCO DE NOTAS DO WINDOWS.
Oct 14 114731 umbrel um7 KBbreld1182.txt (4.)
I checked the TXT you attached. It shows that retro-mike-miningcore failed to install, but only includes the final error, not what caused it. There’s nothing in that snippet pointing to a problem with your laptop.
This MiningCore package comes from Retro Mike’s community app store. The maintainer mentions that he no longer keeps up with Umbrel’s OS changes, so compatibility could be a factor: GitHub - TheRetroMike/retromike-umbrel-app-store: Official Retro Mike Community App Store for Umbrel. These apps are solely managed by me and do not come with any guarantee of uptime. These are all general docker images that can be run with or without Umbrel · GitHub
One thing worth checking: the package expects config.json and coins.json to exist in /home/umbrel/.miningcore/. Have you already created those files, and are you following a particular guide? Installing MiningCore Web UI alone doesn’t replace that configuration.
Could you share your umbrelOS version and a fuller log, including the lines before Failed to install app retro-mike-miningcore? Try installing once more and download the log right after it fails. Just remove any passwords or other private details before posting. The earlier lines should help narrow down what’s going wrong without having to start over again.
Obrigado pela resposta detalhada e por investigar o problema.
Depois de várias tentativas para fazer o MiningCore funcionar, acabei desistindo da instalação e seguindo por outro caminho. Por isso, não preciso mais do suporte relacionado a esse assunto neste momento.
Agradeço muito a disposição em ajudar e o tempo que vocês dedicaram ao caso. Não descarto voltar a tentar no futuro, quando tiver mais tempo para revisar a configuração com calma. Se isso acontecer, certamente voltarei à comunidade para buscar orientação.
Muito obrigado pela ajuda!
