Migrating to Linux, but keeping SSD
If I migrate to a new machine and install Ubuntu Server, can I just mount the SSD from my Pi and run the start scripts to continue where I left off?
Or should I run the install script over the existing location of umbrel inside where I mounted the SSD?
Many users have had permission errors when attempting to do it this way, it may be easier to reinstall like new - I might recommend deleting the Umbrel directory and then reinstalling with the installation command.
I’d recommend this if you don’t have much data and are just running a few applications right now, as a disclaimer this would require to perform a new initial blockchain download. There is a way to copy over the chainstate directories like this: https://github.com/getumbrel/umbrel-os/issues/119#issuecomment-691949967
You can also copy any content from file storage apps that are all stored in the /downloads directory here:
~/umbrel/data/storage/downloads
Let me know if you have any other questions
