Hi yalls,
I am trying to update my Umbrel v0.5.1 to the latest hotfix lnd verison v0.15.2-beta but the ‘Update’ button in my AppStore is not showing up. Could anybody tell me how I can upgrade lnd manually?
Thanks for your help!!
Hi yalls,
This issue has been resolved and was caused by a local network setting… the DNS server on the Umbrel was wrong.
I have the exact same issue. How was this resolved? How was the DNS server changed.
Thanks in advance.
Hi there,
sure so basically I followed the instructions here: How to set a static IP for your Umbrel machine.
Especially in this section
Option B - setup a fix IP in your RPi settings
Add the following to the /etc/dhcpcd.conf file:
#Configuration static IP address (CHANGE THE VALUES TO FIT FOR YOUR NETWORK)
interface eth0
static ip_address=192.168.178.100/24
static routers=192.168.178.1
static domain_name_servers=192.168.178.1
After the changes I had to restart umbrel for it to take effect.
Also as alternative to bypass DNS issues you can use the repo update script
