LND update problem
Hello,
Tried to update to latest lnd version, dashboard showed “updating” for 3 days and now it shows “not running”
Logs:
Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script logs lightning
time=“2024-10-20T17:09:42Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2024-10-20T17:09:42Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.tor.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2024-10-20T17:09:42Z” level=warning msg=“/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2024-10-20T17:09:42Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_IP" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_NODE_DATA_DIR" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_GRPC_HIDDEN_SERVICE" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_NODE_IP" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_REST_HIDDEN_SERVICE" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_COMMAND" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_NODE_PORT" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_NODE_REST_PORT" variable is not set. Defaulting to a blank string.”
time=“2024-10-20T17:09:42Z” level=warning msg=“The "APP_LIGHTNING_NODE_GRPC_PORT" variable is not set. Defaulting to a blank string.”
invalid spec: :/data/.lnd: empty section between colons
please help
I also have the same problem after updating. Output from troubleshooting
time="2024-11-08T00:11:50Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
time="2024-11-08T00:11:50Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.tor.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
time="2024-11-08T00:11:50Z" level=warning msg="/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
time="2024-11-08T00:11:50Z" level=warning msg="networks.default: external.name is deprecated. Please set name and external: true"
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_IP\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_NODE_DATA_DIR\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_GRPC_HIDDEN_SERVICE\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_REST_HIDDEN_SERVICE\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_NODE_IP\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_COMMAND\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_NODE_PORT\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_NODE_REST_PORT\" variable is not set. Defaulting to a blank string."
time="2024-11-08T00:11:50Z" level=warning msg="The \"APP_LIGHTNING_NODE_GRPC_PORT\" variable is not set. Defaulting to a blank string."
I’m unable to update or uninstall the app.
umbrel@umbrel:~$ umbreld client apps.update.mutate --appId lightning
TRPCClientError: Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script pre-patch-update lightning
    at TRPCClientError.from (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/TRPCClientError-38f9a32a.mjs:27:20)
    at file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/links/httpLink.mjs:35:60
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
  meta: {
    response: Response {
      [Symbol(realm)]: null,
      [Symbol(state)]: [Object],
      [Symbol(headers)]: [HeadersList]
    responseJSON: { error: [Object] }
  shape: {
    message: 'Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script pre-patch-update lightning',
    code: -32603,
    data: {
      code: 'INTERNAL_SERVER_ERROR',
      httpStatus: 500,
      stack: 'Error: Command failed with exit code 15: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script pre-patch-update lightning\n' +
        '    at makeError (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/lib/error.js:60:11)\n' +
        '    at handlePromise (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/index.js:124:26)\n' +
        '    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n' +
        '    at App.update (/usr/local/lib/node_modules/umbreld/source/modules/apps/app.ts:163:3)\n' +
        '    at async resolveMiddleware (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:421:30)\n' +
        '    at async callRecursive (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:451:32)\n' +
        '    at async resolve (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/index.mjs:481:24)\n' +
        '    at async inputToProcedureCall (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/server/dist/resolveHTTPResponse-2fc435bb.mjs:46:22)',
      path: 'apps.update',
      zodError: null
  data: {
    httpStatus: 500,
    zodError: null
  [cause]: undefined
Probably the exports.sh shouldn’t be empty. Why would that have happened?
umbrel@umbrel:~/umbrel/app-data/lightning$ ls -al
total 32
drwxr-xr-x  4 umbrel umbrel 4096 Nov  8 13:45 .
drwxrwxr-x 12 umbrel umbrel 4096 Nov  7 23:56 ..
drwxr-xr-x  4 umbrel umbrel 4096 Jul  8  2022 data
-rw-r--r--  1 umbrel umbrel 2690 Nov  8 03:58 docker-compose.yml
-rw-r--r--  1 umbrel umbrel    0 Nov  8 13:45 exports.sh
drwxr-xr-x  2 umbrel umbrel 4096 Nov  8 03:59 hooks
-rw-r--r--  1 umbrel umbrel  178 Nov  8 03:59 torrc
-rw-r--r--  1 umbrel umbrel  334 Nov  7 06:01 torrc.template
-rw-r--r--  1 umbrel umbrel 3211 Nov  7 06:01 umbrel-app.yml
umbrel@umbrel:~/umbrel/app-data/lightning$ cat exports.sh
Any luck with this?
Yes I re-flashed the boot drive, and that fixed the problem.
