Hello,
I had the node synced but needed to restart the system, so at last I did a ubuntu version upgrade, the problem is I cannot boot it, it appear as follows:
can anyone help please, really in the dark…
Regards!
Can you share a little bit about your environment, how are you running the Linux you installed Umbrel to? Is this a vm or bare metal?
Yes a VM, with umbrel but installed server Ubuntu and then the desktop , but now I am unable to boot it after the Install of new version
